Inspire Pro firmware help
2315 12 2018-3-2
fans937e3f83
United Arab Emirates
hi everyone
helping a firend to get his inspire pro up again
not sure to which firmware i need to update since they all fail.
below is the log
can someone point me in the right direction please , thx
========== 2015.12.07 08:52:35 =====================
Packet: WM610_FC550_FW_V01.00.00.30_1012.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: WM610_FC550_FW_V01.04.00.70.bin
Upgrading ...
Result: Success.
========== 2016.03.26 07:34:45 =====================
Result: Abort.
========== 2018.03.02 09:43:56 =====================
Packet: WM610_FC550_FW_V01.11.01.50.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:05 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: WM610_FC550_FW_V01.08.01.00.bin
Result: Failed.
Packet: WM610_FC550_FW_V01.03.00.60.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
2018-3-2
Henry M.Y.
Flight distance : 11548839 ft
In order for us to assist you to diagnose your Inspire 1 Pro FW upgrading problem, please post the content of the log file named "WM610_F550_FW_LOG_AB.txt" inside the hidden folder, not the file named "WM610_F550_FW_RESULT_AB.txt".
Henry
2018-3-2
p25o1
Henry M.Y. Posted at 2018-3-2 21:35
Henry
thanks for pointing me to that
below is the log
[00031115]========== 2015.12.07 08:52:36. boot(15) ============
[00031232]Packet [C:\WM610_FC550_FW_V01.00.00.30_1012.bin] detected, card sn [0xed03096a].
[00031272]Packet upgrade start...
[00031308]Packet checking...
[00031345]Packet vlink 01.00.0030 <-> 01.00.0030.
[00031415]Done.
[00031448]Version checking[1]...
[00031489][01 00][00] v0.34.3973 -> v0.34.3973
[00031520][01 01][00] v0.34.3973 -> v0.34.3973
[00031567][01 04][00] v0.1.3977 -> v0.1.3977
[00031609][04 00][00] v1.28.0.8 -> v1.28.0.5
[00031662][03 05][00] v34.1.0.5 -> v34.1.0.5
[00031723][03 06][00] v2.3.1.1 -> v2.3.1.1
[00031782][05 00][00] v3.0.6.1 -> v3.0.6.1
[00031823][08 00][00] v2.14.9.17 -> v2.14.9.17
[00031870][09 00][00] v1.8.0.0 -> v1.8.0.0
[00031923][11 00][00] v3.7.15.10 -> v3.7.15.10
[00032001][12 00][00] v1.11.0.0 -> v1.11.0.0
[00032081][12 01][00] v1.11.0.0 -> v1.11.0.0
[00032162][12 02][00] v1.11.0.0 -> v1.11.0.0
[00032241][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033897][15 00][00] v1.1.2.0 -> v1.1.2.0
[00033964][17 00][00] v1.1.0.4 -> v1.1.0.4
[00034063][17 01][00] v2.0.0.8 -> v2.0.0.8
[00034105][19 00][00] v1.0.8.96 -> v1.0.8.96
[00036139]Packet upgrade cancelled at version checking.
[00012571]========== remo-con disconnect. boot(15) ============
[00012604]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0xa0ce0e36].
[00012637]Packet upgrade start...
[00012675]Packet checking...
[00012716]Packet vlink 01.04.0070 <-> 01.03.0060.
[00012750]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00012786]Done.
[00012817]Version checking[1]...
[00012853][01 00][00] v0.34.3973 -> v1.19.4923 need upgrade
[00012889][01 01][00] v0.34.3973 -> v1.19.4923 need upgrade
[00012931][01 04][00] v0.1.3977 -> v0.2.4270 need upgrade
[00012982][04 00][00] v1.28.0.8 -> v1.29.0.85 need upgrade.
[00013047][03 05][00] v34.1.0.5 -> v34.1.0.5
[00013127][03 06][00] v2.3.1.1 -> v2.4.10.7 need upgrade.
[00013210][05 00][00] v3.0.6.1 -> v3.0.6.2 need upgrade.
[00013254][08 00][00] v2.14.9.17 -> v2.14.9.26 need upgrade.
[00013405][09 00][00] v1.8.0.0 -> v1.8.0.0
[00013468][11 00][00] v3.8.0.0 -> v3.8.15.4 need upgrade.
[00013568][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013668][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013768][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013868][12 03][00] v1.11.0.0 -> v1.11.0.0
[00015167][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015228][17 00][00] v1.1.0.4 -> v1.1.0.4
[00015328][17 01][00] v2.0.0.8 -> v2.0.1.2 need upgrade.
[00015399][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015434]Done.
[00017466]Waiting for user confirm...
[00027503]Timeout, start upgrade automatically.
[00027582]Firmware upgrading[1]...
[00033196][01 00] Firmware upgrade start...
[00012333][01 00] Firmware upgrade finished successfully.
[00012370]Done.
[00012407]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] resumed, card sn [0xa0ce0e36].
[00012449]Packet vlink 01.04.0070 <-> 01.03.0060.
[00012486]Record vlink 01.00.0030 <-> 01.00.0030 (flow = 0).
[00012529]Version checking[2]...
[00012566][01 00][05] v1.19.4923 -> v1.19.4923
[00012604][01 01][00] v0.34.3973 -> v1.19.4923 need upgrade
[00012645][01 04][00] v0.1.3977 -> v0.2.4270 need upgrade
[00012688][04 00][00] v1.28.0.8 -> v1.29.0.85 need upgrade.
[00012784][03 05][00] v34.1.0.5 -> v34.1.0.5
[00012866][03 06][00] v2.3.1.1 -> v2.4.10.7 need upgrade.
[00012944][05 00][00] v3.0.6.1 -> v3.0.6.2 need upgrade.
[00012992][08 00][00] v2.14.9.17 -> v2.14.9.26 need upgrade.
[00013043][09 00][00] v1.8.0.0 -> v1.8.0.0
[00013123][11 00][00] v3.8.0.0 -> v3.8.15.4 need upgrade.
[00013223][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013324][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013423][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013523][12 03][00] v1.11.0.0 -> v1.11.0.0
[00015007][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015063][17 00][00] v1.1.0.4 -> v1.1.0.4
[00015163][17 01][00] v2.0.0.8 -> v2.0.1.2 need upgrade.
[00015208][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015245]Done.
[00015279]Firmware upgrading[2]...
[00015489][01 01] Firmware upgrade start...
[00045775][01 01] Firmware upgrade finished successfully.
[00045823][01 04] Firmware upgrade start...
[00085208][01 04] Firmware upgrade finished successfully.
[00085922][08 00] Firmware upgrade start...
[00631869][08 00] Firmware upgrade finished successfully.
[00632000][03 06] Firmware upgrade start...
[00880842][03 06] Firmware upgrade finished successfully.
[00880894][17 01] Firmware upgrade start...
[00934635][17 01] Firmware upgrade finished successfully.
[00934677][11 00] Firmware upgrade start...
[00976677][11 00] Firmware upgrade finish failed (step = 4, err = 0xf4, idx = 81, los = 1, ng = 29).
[01006726][05 00] Firmware upgrade start...
[01051412][05 00] Firmware upgrade finished successfully.
[01051484][04 00] Firmware upgrade start...
[01124767][04 00] Firmware upgrade finished successfully.
[01124805]Done.
[01124843]Version checking[3]...
[01124881][01 00][05] v1.19.4923 -> v1.19.4923
[01124922][01 01][05] v1.19.4923 -> v1.19.4923
[01124966][01 04][05] v0.2.4270 -> v0.2.4270
[01125016][04 00][05] v1.29.0.85 -> v1.29.0.85
[01125092][03 05][00] v34.1.0.5 -> v34.1.0.5
[01125173][03 06][05] v2.4.10.7 -> v2.4.10.7
[01125232][05 00][05] v3.0.6.2 -> v3.0.6.2
[01125282][08 00][05] v2.14.9.26 -> v2.14.9.26
[01125369][09 00][00] v1.8.0.0 -> v1.8.0.0
[01125433][11 00][00] v0.0.0.0 -> v3.8.15.4 need upgrade.
[01125533][12 00][00] v1.11.0.0 -> v1.11.0.0
[01125616][12 01][00] v1.11.0.0 -> v1.11.0.0
[01125716][12 02][00] v1.11.0.0 -> v1.11.0.0
[01125816][12 03][00] v1.11.0.0 -> v1.11.0.0
[01125921][15 00][00] v1.1.2.0 -> v1.1.2.0
[01125973][17 00][00] v1.1.0.4 -> v1.1.0.4
[01126093][17 01][05] v2.0.1.2 -> v2.0.1.2
[01126149][19 00][00] v1.0.8.96 -> v1.0.8.96
[01126183]Done.
[01126223]Firmware upgrading[3]...
[01126268][11 00] Firmware upgrade start...
[01212547][11 00] Firmware upgrade finished successfully.
[01212581]Done.
[01212618]Version checking[4]...
[01212655][01 00][05] v1.19.4923 -> v1.19.4923
[01212770][01 01][05] v1.19.4923 -> v1.19.4923
[01212818][01 04][05] v0.2.4270 -> v0.2.4270
[01212865][04 00][05] v1.29.0.85 -> v1.29.0.85
[01212932][03 05][00] v34.1.0.5 -> v34.1.0.5
[01213010][03 06][05] v2.4.10.7 -> v2.4.10.7
[01213090][05 00][05] v3.0.6.2 -> v3.0.6.2
[01213147][08 00][05] v2.14.9.26 -> v2.14.9.26
[01213190][09 00][00] v1.8.0.0 -> v1.8.0.0
[01213270][11 00][05] v3.8.15.4 -> v3.8.15.4
[01213370][12 00][00] v1.11.0.0 -> v1.11.0.0
[01213470][12 01][00] v1.11.0.0 -> v1.11.0.0
[01213570][12 02][00] v1.11.0.0 -> v1.11.0.0
[01213670][12 03][00] v1.11.0.0 -> v1.11.0.0
[01213770][15 00][00] v1.1.2.0 -> v1.1.2.0
[01213832][17 00][00] v1.1.0.4 -> v1.1.0.4
[01213933][17 01][05] v2.0.1.2 -> v2.0.1.2
[01213979][19 00][00] v1.0.8.96 -> v1.0.8.96
[01214020]Packet upgrade finish successfully.
[00012540]========== 2016.03.26 07:34:45. boot(15) ============
[00012579]Packet [C:\WM610_FC550_FW_V01.04.00.70.bin] detected, card sn [0xa0ce0e36].
[00012616]Packet upgrade start...
[00012667]Packet checking...
[00012706]Packet vlink 01.04.0070 <-> 01.03.0060.
[00012742]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00012784]Done.
[00012820]Version checking[1]...
[00012855][01 00][00] v1.19.4923 -> v1.19.4923
[00012900][01 01][00] v1.19.4923 -> v1.19.4923
[00012947][01 04][00] v0.2.4270 -> v0.2.4270
[00012997][04 00][00] v1.29.0.85 -> v1.29.0.85
[00013075][03 05][00] v34.1.0.5 -> v34.1.0.5
[00013135][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013216][05 00][00] v3.0.6.2 -> v3.0.6.2
[00013266][08 00][00] v2.14.9.26 -> v2.14.9.26
[00013315][09 00][00] v1.8.0.0 -> v1.8.0.0
[00013416][11 00][00] v3.8.15.4 -> v3.8.15.4
[00013496][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013596][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013676][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013756][12 03][00] v1.11.0.0 -> v1.11.0.0
[00013882][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013956][17 00][00] v1.1.0.4 -> v1.1.0.4
[00014055][17 01][00] v2.0.1.2 -> v2.0.1.2
[00014215][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016256]Packet upgrade cancelled at version checking.
[00012540]========== 2018.03.02 09:43:56. boot(15) ============
[00012583]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] detected, card sn [0xa0ce0e36].
[00012618]Packet upgrade start...
[00012658]Packet checking...
[00012698]Packet vlink 01.11.0150 <-> 01.11.0150.
[00012734]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00012780]Done.
[00012818]Version checking[1]...
[00012859][04 00][00] v1.29.0.85 -> v1.31.1.67 need upgrade.
[00025397][08 00][00] device not detected.
[00025439][01 00][00] v1.19.4923 -> v1.29.5379 need upgrade
[00025476][01 01][00] v1.19.4923 -> v1.29.5379 need upgrade
[00025518][01 04][00] v0.2.4270 -> v0.5.5085 need upgrade
[00025592][03 05][00] v34.1.0.5 -> v34.1.0.5
[00025656][03 06][00] v2.4.10.7 -> v2.4.20.50 need upgrade.
[00025732][05 00][00] v3.0.6.2 -> v3.0.6.2
[00025780][09 00][00] v1.8.0.0 -> v5.0.0.0 need upgrade.
[00025872][11 00][00] v3.10.0.0 -> v3.9.0.0
[00025952][12 00][00] v1.11.0.0 -> v1.11.0.0
[00026031][12 01][00] v1.11.0.0 -> v1.11.0.0
[00026113][12 02][00] v1.11.0.0 -> v1.11.0.0
[00026211][12 03][00] v1.11.0.0 -> v1.11.0.0
[00038746][15 00][00] device not detected.
[00038810][17 00][00] v1.1.0.4 -> v1.1.0.8 need upgrade.
[00038910][17 01][00] v2.0.1.2 -> v2.0.1.6 need upgrade.
[00038965][19 00][00] v1.0.8.96 -> v1.0.8.96
[00039001]Done.
[00041038]Waiting for user confirm...
[00051075]Timeout, start upgrade automatically.
[00051156]Firmware upgrading[1]...
[00057143][01 00] Firmware upgrade start...
[00007851][01 00] Firmware upgrade finished successfully.
[00007894]Done.
[00007935]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] resumed, card sn [0xa0ce0e36].
[00007975]Packet vlink 01.11.0150 <-> 01.11.0150.
[00008016]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00008051]Version checking[2]...
[00008096][04 00][00] v1.29.0.85 -> v1.31.1.67 need upgrade.
[00020716][08 00][00] device not detected.
[00020760][01 00][05] v1.29.5379 -> v1.29.5379
[00020798][01 01][00] v1.19.4923 -> v1.29.5379 need upgrade
[00020845][01 04][00] v0.2.4270 -> v0.5.5085 need upgrade
[00020921][03 05][00] v34.1.0.5 -> v34.1.0.5
[00021002][03 06][00] v2.4.10.7 -> v2.4.20.50 need upgrade.
[00021081][05 00][00] v3.0.6.2 -> v3.0.6.2
[00021131][09 00][00] v1.8.0.0 -> v5.0.0.0 need upgrade.
[00021221][11 00][00] v3.10.0.0 -> v3.9.0.0
[00021303][12 00][00] v1.11.0.0 -> v1.11.0.0
[00021402][12 01][00] v1.11.0.0 -> v1.11.0.0
[00021480][12 02][00] v1.11.0.0 -> v1.11.0.0
[00021561][12 03][00] v1.11.0.0 -> v1.11.0.0
[00034115][15 00][00] device not detected.
[00034187][17 00][00] v1.1.0.4 -> v1.1.0.8 need upgrade.
[00034301][17 01][00] v2.0.1.2 -> v2.0.1.6 need upgrade.
[00034382][19 00][00] v1.0.8.96 -> v1.0.8.96
[00034419]Done.
[00034457]Firmware upgrading[2]...
[00034559][01 01] Firmware upgrade start...
[00044850][01 01] Firmware upgrade finished successfully.
[00044903][01 04] Firmware upgrade start...
[00070259][01 04] Firmware upgrade finished successfully.
[00070418][03 06] Firmware upgrade start...
[00322548][03 06] Firmware upgrade finished successfully.
[00322606][17 00] Firmware upgrade start...
[00364211][17 00] Firmware upgrade finished successfully.
[00364260][17 01] Firmware upgrade start...
[00398037][17 01] Firmware upgrade finished successfully.
[00398094][09 00] Firmware upgrade start...
[00452985][09 00] Firmware upgrade finished successfully.
[00453058][04 00] Firmware upgrade start...
[00508969][04 00] Firmware upgrade finished successfully.
[00509007]Done.
[00509048]Version checking[3]...
[00509096][04 00][05] v1.31.1.67 -> v1.31.1.67
[00521645][08 00][00] device not detected.
[00521684][01 00][05] v1.29.5379 -> v1.29.5379
[00521722][01 01][05] v1.29.5379 -> v1.29.5379
[00521780][01 04][05] v0.5.5085 -> v0.5.5085
[00521862][03 05][00] v34.1.0.5 -> v34.1.0.5
[00521943][03 06][05] v2.4.20.50 -> v2.4.20.50
[00522103][05 00][00] v3.0.6.2 -> v3.0.6.2
[00522162][09 00][05] v5.0.0.0 -> v5.0.0.0
[00522242][11 00][00] v3.10.0.0 -> v3.9.0.0
[00522322][12 00][00] v1.11.0.0 -> v1.11.0.0
[00522443][12 01][00] v1.11.0.0 -> v1.11.0.0
[00522522][12 02][00] v1.11.0.0 -> v1.11.0.0
[00522622][12 03][00] v1.11.0.0 -> v1.11.0.0
[00535184][15 00][00] device not detected.
[00535261][17 00][05] v1.1.0.8 -> v1.1.0.8
[00535362][17 01][05] v2.0.1.6 -> v2.0.1.6
[00535412][19 00][00] v1.0.8.96 -> v1.0.8.96
[00535452]Packet upgrade failed at version checking.
[00006693]========== remo-con disconnect. boot(15) ============
[00006735]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] detected, card sn [0xa0ce0e36].
[00006784]Packet upgrade start...
[00006831]Packet checking...
[00006883]Packet vlink 01.11.0150 <-> 01.11.0150.
[00006925]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00006971]Done.
[00007013]Version checking[1]...
[00007078][04 00][00] v1.31.1.67 -> v1.31.1.67
[00019616][08 00][00] device not detected.
[00019659][01 00][00] v1.29.5379 -> v1.29.5379
[00019699][01 01][00] v1.29.5379 -> v1.29.5379
[00019755][01 04][00] v0.5.5085 -> v0.5.5085
[00019834][03 05][00] v34.1.0.5 -> v34.1.0.5
[00019914][03 06][00] v2.4.20.50 -> v2.4.20.50
[00019994][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020069][09 00][00] v5.0.0.0 -> v5.0.0.0
[00020154][11 00][00] v3.10.0.0 -> v3.9.0.0
[00020235][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020334][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020436][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020534][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033093][15 00][00] device not detected.
[00033173][17 00][00] v1.1.0.8 -> v1.1.0.8
[00033293][17 01][00] v2.0.1.6 -> v2.0.1.6
[00033348][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035392]Packet upgrade failed at version checking.
[00006692]========== remo-con disconnect. boot(15) ============
[00006734]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] detected, card sn [0xa0ce0e36].
[00006783]Packet upgrade start...
[00006919]Packet checking...
[00006973]Packet vlink 01.11.0150 <-> 01.11.0150.
[00007016]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00007073]Done.
[00007125]Version checking[1]...
[00007179][04 00][00] v1.31.1.67 -> v1.31.1.67
[00019722][08 00][00] device not detected.
[00019761][01 00][00] v1.29.5379 -> v1.29.5379
[00019804][01 01][00] v1.29.5379 -> v1.29.5379
[00019855][01 04][00] v0.5.5085 -> v0.5.5085
[00019916][03 05][00] v34.1.0.5 -> v34.1.0.5
[00019977][03 06][00] v2.4.20.50 -> v2.4.20.50
[00020055][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020105][09 00][00] v5.0.0.0 -> v5.0.0.0
[00020196][11 00][00] v3.10.0.0 -> v3.9.0.0
[00020296][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020396][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020516][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020596][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033139][15 00][00] device not detected.
[00033215][17 00][00] v1.1.0.8 -> v1.1.0.8
[00033335][17 01][00] v2.0.1.6 -> v2.0.1.6
[00033384][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035425]Packet upgrade failed at version checking.
[00006963]========== remo-con disconnect. boot(15) ============
[00007001]Packet [C:\WM610_FC550_FW_V01.08.01.00.bin] detected, card sn [0xa0ce0e36].
[00007039]Packet upgrade start...
[00007083]Packet checking...
[00007127]Packet vlink 01.08.0100 <-> 01.04.0070.
[00007187]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00007243]Done.
[00007289]Version checking[1]...
[00007328][01 00][00] v1.29.5379 -> v1.22.5037
[00007377][01 01][00] v1.29.5379 -> v1.22.5037
[00007422][01 04][00] v0.5.5085 -> v0.2.4270
[00007508][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007608][03 06][00] v2.4.20.50 -> v2.4.10.7
[00007654][04 00][00] v1.31.1.67 -> v1.29.0.92
[00007754][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020314][08 00][00] device not detected.
[00020381][09 00][00] v5.0.0.0 -> v3.0.0.4
[00020468][11 00][00] v3.10.0.0 -> v3.9.0.0
[00020569][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020667][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020848][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020949][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033500][15 00][00] device not detected.
[00033588][17 00][00] v1.1.0.8 -> v1.1.0.4
[00033688][17 01][00] v2.0.1.6 -> v2.0.1.4
[00033739][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035775]Packet upgrade failed at version checking.
[00006704]========== remo-con disconnect. boot(15) ============
[00006750]Packet [C:\WM610_FC550_FW_V01.03.00.60.bin] detected, card sn [0xa0ce0e36].
[00006801]Packet upgrade start...
[00006856]Packet checking...
[00006919]Packet vlink 01.03.0060 <-> 01.00.0030.
[00006985]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 1).
[00007050]Done.
[00007105]Version checking[1]...
[00007148][01 00][00] v1.29.5379 -> v1.9.4499 need upgrade
[00007198][01 01][00] v1.29.5379 -> v1.9.4499 need upgrade
[00007258][01 04][00] v0.5.5085 -> v0.2.4270 need upgrade
[00007317][04 00][00] v1.31.1.67 -> v1.29.0.60 need upgrade.
[00007389][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007489][03 06][00] v2.4.20.50 -> v2.4.10.7 need upgrade.
[00007589][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020152][08 00][00] device not detected.
[00020214][09 00][00] v5.0.0.0 -> v1.8.0.0
[00020309][11 00][00] v3.10.0.0 -> v3.8.15.4
[00020409][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020509][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020609][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020688][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033231][15 00][00] device not detected.
[00033308][17 00][00] v1.1.0.8 -> v1.1.0.4 need upgrade.
[00033408][17 01][00] v2.0.1.6 -> v2.0.1.2 need upgrade.
[00033479][19 00][00] v1.0.8.96 -> v1.0.8.96
[00033521]Done.
[00037075]Waiting for user confirm...
[00047115]Timeout, start upgrade automatically.
[00047200]Firmware upgrading[1]...
[00047294][01 01] Firmware upgrade start...
[00057577][01 01] Firmware upgrade finished successfully.
[00057629][01 04] Firmware upgrade start...
[00082966][01 04] Firmware upgrade finished successfully.
[00083151][03 06] Firmware upgrade start...
[00305837][03 06] Firmware upgrade finished successfully.
[00305892][17 00] Firmware upgrade start...
[00347616][17 00] Firmware upgrade finished successfully.
[00347669][17 01] Firmware upgrade start...
[00381336][17 01] Firmware upgrade finished successfully.
[00381395][04 00] Firmware upgrade start...
[00428728][04 00] Firmware upgrade finished successfully.
[00428767]Done.
[00428806]Version checking[2]...
[00428847][01 00][00] v1.29.5379 -> v1.9.4499 need upgrade
[00428888][01 01][05] v1.9.4499 -> v1.9.4499
[00428946][01 04][05] v0.2.4270 -> v0.2.4270
[00428995][04 00][05] v1.29.0.60 -> v1.29.0.60
[00429078][03 05][00] v34.1.0.5 -> v34.1.0.5
[00429138][03 06][05] v2.4.10.7 -> v2.4.10.7
[00429217][05 00][00] v3.0.6.2 -> v3.0.6.2
[00441765][08 00][00] device not detected.
[00441817][09 00][00] v5.0.0.0 -> v1.8.0.0
[00441897][11 00][00] v3.10.0.0 -> v3.8.15.4
[00441996][12 00][00] v1.11.0.0 -> v1.11.0.0
[00442097][12 01][00] v1.11.0.0 -> v1.11.0.0
[00442196][12 02][00] v1.11.0.0 -> v1.11.0.0
[00442296][12 03][00] v1.11.0.0 -> v1.11.0.0
[00454840][15 00][00] device not detected.
[00454896][17 00][05] v1.1.0.4 -> v1.1.0.4
[00454997][17 01][05] v2.0.1.2 -> v2.0.1.2
[00455052][19 00][00] v1.0.8.96 -> v1.0.8.96
[00455091]Packet upgrade failed at version checking.
[00006873]========== remo-con disconnect. boot(15) ============
[00006914]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] detected, card sn [0xa0ce0e36].
[00006957]Packet upgrade start...
[00007006]Packet checking...
[00007054]Packet vlink 01.11.0150 <-> 01.11.0150.
[00007120]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00007173]Done.
[00007216]Version checking[1]...
[00007273][04 00][00] v1.29.0.60 -> v1.31.1.67 need upgrade.
[00019817][08 00][00] device not detected.
[00019860][01 00][00] v1.29.5379 -> v1.29.5379
[00019899][01 01][00] v1.9.4499 -> v1.29.5379 need upgrade
[00019944][01 04][00] v0.2.4270 -> v0.5.5085 need upgrade
[00020110][03 05][00] v34.1.0.5 -> v34.1.0.5
[00020190][03 06][00] v2.4.10.7 -> v2.4.20.50 need upgrade.
[00020290][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020344][09 00][00] v5.0.0.0 -> v5.0.0.0
[00020430][11 00][00] v3.10.0.0 -> v3.9.0.0
[00020530][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020630][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020729][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020829][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033370][15 00][00] device not detected.
[00033431][17 00][00] v1.1.0.4 -> v1.1.0.8 need upgrade.
[00033531][17 01][00] v2.0.1.2 -> v2.0.1.6 need upgrade.
[00033584][19 00][00] v1.0.8.96 -> v1.0.8.96
[00033624]Done.
[00037177]Waiting for user confirm...
[00047216]Timeout, start upgrade automatically.
[00047297]Firmware upgrading[1]...
[00047386][01 01] Firmware upgrade start...
[00057662][01 01] Firmware upgrade finished successfully.
[00057712][01 04] Firmware upgrade start...
[00083052][01 04] Firmware upgrade finished successfully.
[00083178][03 06] Firmware upgrade start...
[00331158][03 06] Firmware upgrade finished successfully.
[00331212][17 00] Firmware upgrade start...
[00372437][17 00] Firmware upgrade finished successfully.
[00372486][17 01] Firmware upgrade start...
[00406215][17 01] Firmware upgrade finished successfully.
[00406282][04 00] Firmware upgrade start...
[00459086][04 00] Firmware upgrade finished successfully.
[00459129]Done.
[00459168]Version checking[2]...
[00459216][04 00][05] v1.31.1.67 -> v1.31.1.67
[00471767][08 00][00] device not detected.
[00471824][01 00][00] v1.29.5379 -> v1.29.5379
[00471869][01 01][05] v1.29.5379 -> v1.29.5379
[00471917][01 04][05] v0.5.5085 -> v0.5.5085
[00471999][03 05][00] v34.1.0.5 -> v34.1.0.5
[00472104][03 06][05] v2.4.20.50 -> v2.4.20.50
[00472199][05 00][00] v3.0.6.2 -> v3.0.6.2
[00472272][09 00][00] v5.0.0.0 -> v5.0.0.0
[00472357][11 00][00] v3.10.0.0 -> v3.9.0.0
[00472457][12 00][00] v1.11.0.0 -> v1.11.0.0
[00472537][12 01][00] v1.11.0.0 -> v1.11.0.0
[00472717][12 02][00] v1.11.0.0 -> v1.11.0.0
[00472800][12 03][00] v1.11.0.0 -> v1.11.0.0
[00485346][15 00][00] device not detected.
[00485416][17 00][05] v1.1.0.8 -> v1.1.0.8
[00485537][17 01][05] v2.0.1.6 -> v2.0.1.6
[00485591][19 00][00] v1.0.8.96 -> v1.0.8.96
[00485635]Packet upgrade failed at version checking.
[00006969]========== remo-con disconnect. boot(15) ============
[00007014]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] detected, card sn [0xa0ce0e36].
[00007057]Packet upgrade start...
[00007110]Packet checking...
[00007168]Packet vlink 01.11.0150 <-> 01.11.0150.
[00007214]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00007257]Done.
[00007306]Version checking[1]...
[00007382][04 00][00] v1.31.1.67 -> v1.31.1.67
[00019942][08 00][00] device not detected.
[00019985][01 00][00] v1.29.5379 -> v1.29.5379
[00020027][01 01][00] v1.29.5379 -> v1.29.5379
[00020087][01 04][00] v0.5.5085 -> v0.5.5085
[00020157][03 05][00] v34.1.0.5 -> v34.1.0.5
[00020217][03 06][00] v2.4.20.50 -> v2.4.20.50
[00020317][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020370][09 00][00] v5.0.0.0 -> v5.0.0.0
[00020456][11 00][00] v3.10.0.0 -> v3.9.0.0
[00020536][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020616][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020720][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020797][12 03][00] v1.11.0.0 -> v1.11.0.0
[00020982][15 00][00] v1.1.2.0 -> v1.1.2.0
[00021063][17 00][00] v1.1.0.8 -> v1.1.0.8
[00021176][17 01][00] v2.0.1.6 -> v2.0.1.6
[00021226][19 00][00] v1.0.8.96 -> v1.0.8.96
[00023268]Packet upgrade failed at version checking.
[00006590]========== remo-con disconnect. boot(15) ============
[00006637]Packet [C:\WM610_FC550_FW_V01.11.01.50.bin] detected, card sn [0xa0ce0e36].
[00006687]Packet upgrade start...
[00006759]Packet checking...
[00006816]Packet vlink 01.11.0150 <-> 01.11.0150.
[00006861]Record vlink 01.04.0070 <-> 01.03.0060 (flow = 0).
[00006902]Done.
[00006954]Version checking[1]...
[00007088][04 00][00] v1.31.1.67 -> v1.31.1.67
[00019651][08 00][00] device not detected.
[00019697][01 00][00] v1.29.5379 -> v1.29.5379
[00019742][01 01][00] v1.29.5379 -> v1.29.5379
[00019788][01 04][00] v0.5.5085 -> v0.5.5085
[00019880][03 05][00] v34.1.0.5 -> v34.1.0.5
[00019959][03 06][00] v2.4.20.50 -> v2.4.20.50
[00020039][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020094][09 00][00] v5.0.0.0 -> v5.0.0.0
[00020199][11 00][00] v3.10.0.0 -> v3.9.0.0
[00020281][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020359][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020439][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020519][12 03][00] v1.11.0.0 -> v1.11.0.0
[00033066][15 00][00] device not detected.
[00033139][17 00][00] v1.1.0.8 -> v1.1.0.8
[00033238][17 01][00] v2.0.1.6 -> v2.0.1.6
[00033289][19 00][00] v1.0.8.96 -> v1.0.8.96
[00035334]Packet upgrade failed at version checking.
2018-3-2
DJI Elektra
p25o1 Posted at 2018-3-2 22:50
below is the log
Please check the connector between the camera and adapter. I would recommend you clean it and install it again. Also, you can check the 8 pin and 10 pin cable above the camera and see if it is well-connected. Thanks for your support.
2018-3-3
Henry M.Y.
below is the log
The log file reveals to me that it is the famous “device not detected” case. The log file indicates that on 2 March 2018, there was a FW upgrading attempt to the Inspire 1 Pro but was not successful for the reason that the remote controller was switched on during the aircraft FW upgrade. As a result both Device ID [08 00] and Device ID [15 00] were damaged and thus were not detected in the course of that upgrade, and will not be detectable again in any further upgrading attempt even with remote controller off.
You will have no choice but to send the Inspire 1 Pro back to DJI for repairing.
Henry
2018-3-3
p25o1
thx , did the cleaning but it didn't help
2018-3-4
p25o1
Henry M.Y. Posted at 2018-3-3 01:35
thx , i'll talk to the local dealer to see if they can address this issue.  is there anything that i can do at home to address this , will the PC app help to fix these type of issues ?
2018-3-4
Donnie -
Flight distance : 3636782 ft
DJI Elektra Posted at 2018-3-3 00:08
Do you actually read the Log and examine it ?  Just wondering why the "Pros" at DJI cant recognize when a camera has a bad Encoder module on the unit  when most of us experienced forum members can  spot that immediately . I have seen this time and time again , then. one of the members has to step in and give the REALITY that the camera at minimum would need to be sent in becasue the unit will not be able to update or give live video with this error on it .
donnie
2018-3-4
Henry M.Y.
p25o1 Posted at 2018-3-4 07:01
It appears that the Inspire 1 Pro must be sent back to DJI for replacement of video encoding & transmission modules.
Henry
2018-3-4
oldgio
Flight distance : 564242 ft
Henry M.Y. Posted at 2018-3-4 15:08
It appears that the Inspire 1 Pro must be sent back to DJI for replacement of video encoding &amp; transmission modules.
Henry
Hello everyone, I also have a similar problem, I bought used an inspire 1 pro with two cameras, x3 and x5. When I mounted the x3 on another inspire 1 I saw that I had no image return but the camera recorded and moved correctly, I tried inspire 1pro with the same result. At this point I tried to update the FW but after few minutes the update has failed, tried again and again several times with failure and at some point was made as it results from the text of the folder that is created, precise that I used the x3. Result, nothing has changed, always absent image, checking I noticed that I had mistakenly used the FW of the RAW version. I tried to update with correct version for x3 but nothing to do, always interrupted process with failure.
Now I wonder; why this happened, a response certainly comes from the hidden files that tell me that the 0800 and 1500 lines are device not detected  I did not make a test, since it is claimed that the transmission card is damaged, I have I put the x3 on an osmo and in this the camera works perfectly even with the image return on the iphone or ipad. At this point how should I proceed to ensure that the inspire 1 pro is correctly updated with the FW, possibly the version previously installed, and resume the x3, also what is the procedure for the correct update of the FW on inspire 1 pro, must use the x5 and the FW for this version and automatically the x3 will be detected, or how did I use the x3 and insert the sd with FW for the pro?
I understand that I have many doubts and I would be grateful if they were clarified
Thank you
Gio
[00016372]========== 2015.08.21 10:17:52. boot(15) ============
[00016488]Packet [C:\WM610_FW_V01.03.00.10.bin] detected, card sn [0xe10390c4].
[00016531]Packet upgrade start...
[00016571]Packet checking...
[00016610]Packet vlink 01.03.0010 &lt;-&gt; 01.02.0000.
[00016679]Done.
[00016721]Version checking[1]...
[00016755][01 00][00] v1.19.3422 -&gt; v1.19.3422
[00016790][01 01][00] v1.19.3422 -&gt; v1.19.3422
[00016854][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00016934][03 06][00] v2.2.6.33 -&gt; v2.2.6.33
[00016976][04 00][00] v1.26.0.21 -&gt; v1.26.0.21
[00017034][05 00][00] v3.0.6.1 -&gt; v3.0.6.1
[00017086][08 00][00] v1.14.0.25 -&gt; v1.14.0.25
[00017154][09 00][00] v1.8.0.0 -&gt; v1.8.0.0
[00017214][11 00][00] v3.7.15.9 -&gt; v3.7.15.9
[00017314][12 00][00] v1.8.0.0 -&gt; v1.8.0.0
[00017415][12 01][00] v1.8.0.0 -&gt; v1.8.0.0
[00017513][12 02][00] v1.8.0.0 -&gt; v1.8.0.0
[00017613][12 03][00] v1.8.0.0 -&gt; v1.8.0.0
[00017756][15 00][00] v1.1.2.0 -&gt; v1.1.2.0
[00017814][17 00][00] v1.1.0.4 -&gt; v1.1.0.4
[00017921][17 01][00] v2.0.0.8 -&gt; v2.0.0.8
[00017963][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00019998]Packet upgrade cancelled at version checking.
[00004910]========== remo-con disconnect. boot(15) ============
[00004943]Packet [C:\WM610_FW_V01.04.00.10.bin] detected, card sn [0x285019ab].
[00004981]Packet upgrade start...
[00005019]Packet checking...
[00005051]Packet vlink 01.04.0010 &lt;-&gt; 01.03.0000.
[00005090]Record vlink 01.03.0010 &lt;-&gt; 01.02.0000 (flow = 0).
[00005130]Done.
[00005174]Version checking[1]...
[00005224][01 00][00] v1.19.3422 -&gt; v1.19.3422
[00005269][01 01][00] v1.19.3422 -&gt; v1.19.3422
[00005351][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00005431][03 06][00] v2.2.6.33 -&gt; v2.3.0.13 need upgrade.
[00005485][04 00][00] v1.26.0.21 -&gt; v1.26.0.21
[00005551][05 00][00] v3.0.6.1 -&gt; v3.0.6.1
[00005598][08 00][00] v1.14.0.25 -&gt; v1.14.0.25
[00005641][09 00][00] v1.8.0.0 -&gt; v1.8.0.0
[00005713][11 00][00] v3.7.1.0 -&gt; v3.7.15.10 need upgrade.
[00005791][12 00][00] v1.8.0.0 -&gt; v1.8.0.0
[00006030][12 01][00] v1.8.0.0 -&gt; v1.8.0.0
[00006130][12 02][00] v1.8.0.0 -&gt; v1.8.0.0
[00006230][12 03][00] v1.8.0.0 -&gt; v1.8.0.0
[00006388][15 00][00] v1.1.2.0 -&gt; v1.1.2.0
[00006450][17 00][00] v1.1.0.4 -&gt; v1.1.0.4
[00006551][17 01][00] v2.0.0.8 -&gt; v2.0.0.8
[00006597][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00006632]Done.
[00008669]Waiting for user confirm...
[00018706]Timeout, start upgrade automatically.
[00018784]Firmware upgrading[1]...
[00018991][03 06] Firmware upgrade start...
[00253308][03 06] Firmware upgrade finished successfully.
[00253353][11 00] Firmware upgrade start...
[00334383][11 00] Firmware upgrade finished successfully.
[00334421]Done.
[00334456]Version checking[2]...
[00334491][01 00][00] v1.19.3422 -&gt; v1.19.3422
[00334531][01 01][00] v1.19.3422 -&gt; v1.19.3422
[00334603][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00334683][03 06][05] v2.3.0.13 -&gt; v2.3.0.13
[00334765][04 00][00] v1.26.0.21 -&gt; v1.26.0.21
[00334823][05 00][00] v3.0.6.1 -&gt; v3.0.6.1
[00334876][08 00][00] v1.14.0.25 -&gt; v1.14.0.25
[00334922][09 00][00] v1.8.0.0 -&gt; v1.8.0.0
[00334987][11 00][05] v3.7.15.10 -&gt; v3.7.15.10
[00335062][12 00][00] v1.8.0.0 -&gt; v1.8.0.0
[00335142][12 01][00] v1.8.0.0 -&gt; v1.8.0.0
[00335242][12 02][00] v1.8.0.0 -&gt; v1.8.0.0
[00335322][12 03][00] v1.8.0.0 -&gt; v1.8.0.0
[00335443][15 00][00] v1.1.2.0 -&gt; v1.1.2.0
[00338002][17 00][00] v1.1.0.4 -&gt; v1.1.0.4
[00338102][17 01][00] v2.0.0.8 -&gt; v2.0.0.8
[00338157][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00338200]Packet upgrade finish successfully.
[00000665][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00007049]========== remo-con disconnect. boot(15) ============
[00007094]Packet [C:\WM610_FW_V01.11.01.50.bin] detected, card sn [0x990fe1af].
[00007146]Packet upgrade start...
[00007201]Packet checking...
[00007265]Packet vlink 01.11.0150 &lt;-&gt; 01.11.0150.
[00007316]Record vlink 01.04.0010 &lt;-&gt; 01.03.0000 (flow = 0).
[00007367]Done.
[00007404]Version checking[1]...
[00007458][04 00][00] v1.26.0.21 -&gt; v1.30.1.43 need upgrade.
[00020003][08 00][00] device not detected.
[00020044][01 00][00] v1.19.3422 -&gt; v2.70.5440 need upgrade
[00020079][01 01][00] v1.19.3422 -&gt; v2.70.5440 need upgrade
[00020161][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00020241][03 06][00] v2.4.20.28 -&gt; v2.4.20.50 need upgrade.
[00020321][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00020372][09 00][00] v3.1.0.0 -&gt; v5.0.0.0 need upgrade.
[00020460][11 00][00] v3.3.0.0 -&gt; v3.9.0.0 need upgrade.
[00020561][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00020640][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00020741][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00020841][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00033376][15 00][00] device not detected.
[00033459][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00033559][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00033604][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00033640]Done.
[00035679]Waiting for user confirm...
[00045711]Timeout, start upgrade automatically.
[00045785]Firmware upgrading[1]...
[00060398][01 00] Firmware upgrade start...
[00023079][01 00] Firmware upgrade finished successfully.
[00023115]Done.
[00023147]Packet [C:\WM610_FW_V01.11.01.50.bin] resumed, card sn [0x990fe1af].
[00023189]Packet vlink 01.11.0150 &lt;-&gt; 01.11.0150.
[00023227]Record vlink 01.04.0010 &lt;-&gt; 01.03.0000 (flow = 0).
[00023260]Version checking[2]...
[00023307][04 00][00] v1.26.0.21 -&gt; v1.30.1.43 need upgrade.
[00035851][08 00][00] device not detected.
[00035886][01 00][05] v2.70.5440 -&gt; v2.70.5440
[00036006][01 01][00] v1.19.3422 -&gt; v2.70.5440 need upgrade
[00036071][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00036130][03 06][00] v2.4.20.28 -&gt; v2.4.20.50 need upgrade.
[00036219][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00036266][09 00][00] v3.1.0.0 -&gt; v5.0.0.0 need upgrade.
[00036330][11 00][00] v3.3.0.0 -&gt; v3.9.0.0 need upgrade.
[00036430][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00036510][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00036610][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00036710][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00049259][15 00][00] device not detected.
[00049309][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00049429][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00049480][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00049516]Done.
[00049555]Firmware upgrading[2]...
[00049646][01 01] Firmware upgrade start...
[00059928][01 01] Firmware upgrade finished successfully.
[00060075][03 06] Firmware upgrade start...
[00307702][03 06] Firmware upgrade finished successfully.
[00307756][11 00] Firmware upgrade start...
[00374976][11 00] Firmware upgrade finished successfully.
[00375034][09 00] Firmware upgrade start...
[00405633][09 00] Firmware upgrade finished successfully.
[00405698][04 00] Firmware upgrade start...
[00460360][04 00] Firmware upgrade finished successfully.
[00460397]Done.
[00460431]Version checking[3]...
[00460478][04 00][05] v1.30.1.43 -&gt; v1.30.1.43
[00473021][08 00][00] device not detected.
[00473058][01 00][05] v2.70.5440 -&gt; v2.70.5440
[00473094][01 01][05] v2.70.5440 -&gt; v2.70.5440
[00473166][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00473226][03 06][05] v2.4.20.50 -&gt; v2.4.20.50
[00473286][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00473331][09 00][05] v5.0.0.0 -&gt; v5.0.0.0
[00473406][11 00][05] v3.9.0.0 -&gt; v3.9.0.0
[00473486][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00473566][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00473646][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00473726][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00486263][15 00][00] device not detected.
[00486324][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00486505][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00486584][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00486620]Packet upgrade failed at version checking.
[00006629]Packet [C:\WM610_FW_V01.11.01.50.bin] detected, card sn [0x990fe1af].
[00006672]Packet upgrade start...
[00006715]Packet checking...
[00006765]Packet vlink 01.11.0150 &lt;-&gt; 01.11.0150.
[00006809]Record vlink 01.04.0010 &lt;-&gt; 01.03.0000 (flow = 0).
[00006847]Done.
[00006896]Version checking[1]...
[00006943][04 00][00] v1.30.1.43 -&gt; v1.30.1.43
[00019502][08 00][00] device not detected.
[00019538][01 00][00] v2.70.5440 -&gt; v2.70.5440
[00019577][01 01][00] v2.70.5440 -&gt; v2.70.5440
[00019645][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00019725][03 06][00] v2.4.20.50 -&gt; v2.4.20.50
[00019804][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00019850][09 00][00] v5.0.0.0 -&gt; v5.0.0.0
[00019904][11 00][00] v3.9.0.0 -&gt; v3.9.0.0
[00020004][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00020104][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00020204][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00020284][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00032820][15 00][00] device not detected.
[00032884][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00032983][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00033032][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00035069]Packet upgrade failed at version checking.
[00006706]========== remo-con disconnect. boot(15) ============
[00006741]Packet [C:\WM610_FW_V01.11.01.50.bin] detected, card sn [0x990fe1af].
[00006785]Packet upgrade start...
[00006829]Packet checking...
[00006876]Packet vlink 01.11.0150 &lt;-&gt; 01.11.0150.
[00006926]Record vlink 01.04.0010 &lt;-&gt; 01.03.0000 (flow = 0).
[00006975]Done.
[00007014]Version checking[1]...
[00007077][04 00][00] v1.30.1.43 -&gt; v1.30.1.43
[00019620][08 00][00] device not detected.
[00019655][01 00][00] v2.70.5440 -&gt; v2.70.5440
[00019695][01 01][00] v2.70.5440 -&gt; v2.70.5440
[00019761][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00019848][03 06][00] v2.4.20.50 -&gt; v2.4.20.50
[00020001][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00020052][09 00][00] v5.0.0.0 -&gt; v5.0.0.0
[00020121][11 00][00] v3.9.0.0 -&gt; v3.9.0.0
[00020221][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00020321][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00020421][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00020541][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00033085][15 00][00] device not detected.
[00033160][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00033260][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00033314][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00035354]Packet upgrade failed at version checking.
[00006597]========== remo-con disconnect. boot(15) ============
[00006636]Packet [C:\WM610_FW_V01.11.01.50.bin] detected, card sn [0x990fe1af].
[00006680]Packet upgrade start...
[00006725]Packet checking...
[00006774]Packet vlink 01.11.0150 &lt;-&gt; 01.11.0150.
[00006823]Record vlink 01.04.0010 &lt;-&gt; 01.03.0000 (flow = 0).
[00006869]Done.
[00006909]Version checking[1]...
[00006976][04 00][00] v1.30.1.43 -&gt; v1.30.1.43
[00019532][08 00][00] device not detected.
[00019572][01 00][00] v2.70.5440 -&gt; v2.70.5440
[00019610][01 01][00] v2.70.5440 -&gt; v2.70.5440
[00019699][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00019770][03 06][00] v2.4.20.50 -&gt; v2.4.20.50
[00019829][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00019880][09 00][00] v5.0.0.0 -&gt; v5.0.0.0
[00019929][11 00][00] v3.9.0.0 -&gt; v3.9.0.0
[00020009][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00020089][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00020190][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00020270][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00032809][15 00][00] device not detected.
[00032890][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00035490][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00035540][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00037583]Packet upgrade failed at version checking.
[00006538]========== remo-con disconnect. boot(15) ============
[00006585]Packet [C:\WM610_FW_V01.11.01.50.bin] detected, card sn [0xf0d80c13].
[00006626]Packet upgrade start...
[00006672]Packet checking...
[00006805]Packet vlink 01.11.0150 &lt;-&gt; 01.11.0150.
[00006847]Record vlink 01.04.0010 &lt;-&gt; 01.03.0000 (flow = 0).
[00006897]Done.
[00006935]Version checking[1]...
[00007002][04 00][00] v1.30.1.43 -&gt; v1.30.1.43
[00019568][08 00][00] device not detected.
[00019606][01 00][00] v2.70.5440 -&gt; v2.70.5440
[00019644][01 01][00] v2.70.5440 -&gt; v2.70.5440
[00019713][03 05][00] v34.1.0.5 -&gt; v34.1.0.5
[00019792][03 06][00] v2.4.20.50 -&gt; v2.4.20.50
[00019852][05 00][00] v3.0.6.2 -&gt; v3.0.6.2
[00019901][09 00][00] v5.0.0.0 -&gt; v5.0.0.0
[00019973][11 00][00] v3.9.0.0 -&gt; v3.9.0.0
[00020072][12 00][00] v1.11.0.0 -&gt; v1.11.0.0
[00020174][12 01][00] v1.11.0.0 -&gt; v1.11.0.0
[00020272][12 02][00] v1.11.0.0 -&gt; v1.11.0.0
[00020372][12 03][00] v1.11.0.0 -&gt; v1.11.0.0
[00032911][15 00][00] device not detected.
[00032991][17 00][00] v1.1.0.8 -&gt; v1.1.0.8
[00033090][17 01][00] v2.0.1.6 -&gt; v2.0.1.6
[00033135][19 00][00] v1.0.8.96 -&gt; v1.0.8.96
[00035176]Packet upgrade failed at version checking.
2018-4-6
Henry M.Y.
oldgio Posted at 2018-4-6 01:30
Hi Gio,
With the devices 08 00 and 15 00 not detected, the only way to make good the Inspire 1 Pro is to send it in to DJI for repairing / replacing.
The proper way of updating an Inspire 1 or Inspire 1 Pro is to update the aircraft first with the remote controller SWITCHED OFF. After successfully update the aircraft, switch it off and unload the bin file and the update log files to your PC or Mac and check through the log files to confirm whether the update was successful. Only then you should start updating your remote controller via DJI GO App with the aircraft SWITCHED OFF.
To ensure that everything will work fine, I would recommend you to send the whole set of Inspire 1 Pro including the aircraft, the remote controller, the X3 and the X5 to DJI for repairing.
Hope this help.
Henry
2018-4-6
oldgio
Henry M.Y. Posted at 2018-4-6 19:54
Hi Gio,
Thanks, I contacted DJI and I will send the whole set as you advised me, I hope they solve quickly and above all that it does not cost as much as the x3 that however on osmo works properly. This is always strange to me, but it is so, I can not understand why. Also I tried again to install the FW, obviously failing, but in the hidden files you can now see two folders with the name osmo? strange
2018-4-7
HUBCAM
Hi Guys!
O.K., next up ...
I have the same issue. Trying to update an Inspire 1 with X5.
Latest firmware into fresh micro sd, gives me blinking red/green, then solid red.
Looking at the text log as you posted earlier just says "Failed".
How do I access the "hidden logs"?
John
2019-3-29
