Mavic air gimbal is not level when auto gimbal calibrate.
7393 18 2018-3-2
djiuser_kwcIcCqh75sv
Flight distance : 134701 ft
Thailand
Hi,
today I fly over the ocean and I regconize that my mavic air horizon line is not level.
when I back home, I try to auto calibrate gimbal and the result is .. not good.
I have to manual adjust gimbal to 0.6 and then it's look good.
so is it normal to have to manually adjust the roll to get it even?
I know mavic pro have problem with gimbal but never heard on mavic air have a same problem too.
2018-3-2
$gambino$
Flight distance : 1563980 ft
Yes gimbals are not perfect....u will have to use adjust gimbal roll especially on windy days. My mav pro always required the right side to be .07
2018-3-2
Thailand
ok thank you,
I think mavic air and new gimbal design will  get rid of this problem.
2018-3-2
StanfordWebbie
Flight distance : 178018 ft
Hope so.  My gimbal is also off 7 degrees, but it's been that way for a long time.  Not getting better or worse.  You should know, of course, that you can adjust the gimbal tilt in settings up to (i think) 10 degrees.
2018-3-2
DJI Thor
Flight distance : 13602 ft
It is okay for your case. Basically, it regards as normal if it is within +/- 3 degrees. For your case, I suggest that you calibrate the gimbal once again after adjusting it back to balance. See if it helps.
2018-3-4
Matthias_HH
Flight distance : 3655 ft
Hi! I have just bought a Mavir Air and made the first flights. Unfortunately, I must say that i have the same problem with the horizon which not exactly. As you can see on the video, the horizon is ok at the beginning of the video, but then tilts as soon as I swivel the Mavic 360 degrees.
dropbox.com/s/82g8nck4qt3a737/DJI_0018_DEMO%20FUER%20SCHIEFLAGE.MP4?dl=0
I have already recalibrated the gimbal and also performed the IMO calibration. but unfortunately the result is what you can be seen on the video. When I flew, it was also relatively calm. I think the Gibal has to make up some wind. Is that a drone error and I have to exchange it or is it normal?
I am happy about any help
Matthias
2018-10-6
Reclaimer106
Flight distance : 427382 ft
I got the same problem Matthias. Mine is actually much worse, see https://forum.dji.com/thread-166674-1-1.html, which is almost the same topic
2018-10-8
Matthias_HH
Hi Reclaimer106 ,
I sent my drone to DJI yesterday, hoping it will come back soon
2018-10-8
Reclaimer106
Im curious what they will say and if they can fix it. If you google around for this issue you can find many others who have the same problem. Keep me updated on the progress if you dont mind ^^
2018-10-9
Matthias_HH
After 10 days I got a new drone back. Now everything works :-) Thanks DJI!
2018-11-2
GinoC
Flight distance : 63507 ft
DJI Thor Posted at 2018-3-4 23:35
It is okay for your case. Basically, it regards as normal if it is within +/- 3 degrees. For your case, I suggest that you calibrate once again after adjusting it back to balance. See if it helps.
which calibration? gimbal or IMU?
2019-9-6
DJI Thor
GinoC Posted at 9-6 04:04
Sorry for the confusion, Gino, it's gimbal calibration.
2019-9-8
DAFlys
You can also manually dial in a correction too.
2019-9-8
GinoC
DJI Thor Posted at 9-8 19:26
so you adjust the horizon manually and then perform a gimbal calibration afterwards?? Will it remember the manually adjusted setting then?
2019-9-10
GinoC
DAFlys Posted at 9-8 23:50
yes i understand, and that is what i did.
What i didn't understand was the advice of Dji Thor to do a gimbal calibration afterwards.
As i think this will erase the manual horizon setting again...
2019-9-10
DAFlys
GinoC Posted at 9-10 01:58
My understanding is the auto calibration would reset your manual settings.
2019-9-10
GinoC
DAFlys Posted at 9-10 02:00
That's what i was thinking also, thanks for your reply
2019-9-10
DAFlys
GinoC Posted at 9-10 03:24
I suppose you could test it and see what happens,  and then we can go definitive
2019-9-10
DJI Thor
GinoC Posted at 9-10 01:57
Please try and see if that helps. Please let me know if the issue persists. Thank you.
2019-9-11
