TexasAerials
Flight distance : 566952 ft
the platinum has the same motors, just the esc method for controlling the pulses of power to the motors to regulate speed is improved. the pro platinum props cause the motors to spin about 4-500 rpm slower in a hover than the standard props, as they have a slightly higher pitch than the standard props as well. the stock props are 8.3" and a 3" pitch, while the platinums are 8.3" and 3.1" pitch. they have a wider blade as well, that makes them a little more efficient in moving air, so a big part of the noise reduction comes from the lower rpm that the motors are turning, and the remainder comes from the design of the tips of the blades (fastest moving part of the blade). which reduces the high pitched buzz or whine from the drone in flight. finally, DJI says there is no problem running the platinum props on the standard mavic pro. |
