Bashy
Flight distance : 2354357 ft
Its a non recommended device, all you will get from dji is to use a device from their recommended list.
They do not test all devices....
As a side note, as dcap says, but with a bit of added flavour
Ignore, youve found it go in to apps and click the 3 dots top right and choose clear default apps, next time you you connect to the app DO NOT choose to have it default to to the dji go app, you want to always click on the app when it pops up, this also aids in what dcap says, when you try to reconnect it does not always do it, but when its not the default app you will find that this helps greatly
Just going over your reply again, youve already found out about the default app clearing etc, thats good, least it works now, i did reply to others regarding this and forgot about this part and just remembered about it. you have now gone as far as you can. |
