menten
Flight distance : 48957 ft
Yes you can fix it by shorting the gimbal to reset it. Then load the update again. It took me three times before it took, and I had to short it each time first.
P.S.
the process of shorting the gimbal can be found on this forum, but basically you tack a paperclip and touch two points on the gimbal while you cycle the battery. It WILL work 100%
