kirbyvid
Flight distance : 2844 ft
Hi,
I happen to use Imperial measurements, so when I select Imperial that only changes the main screen readings
to feet and mph. I would like to show that change from Metric to Imperial inside the various settings in the menus
to be uniform across the application.
The measurement setting should be for global units within the app and not just for the main screen.
I believe operators can get confused when making decisions in the settings which can cause problems for the software.
Thanks.
