TexAsian
Flight distance : 29934 ft
Did you ever get to the bottom of this? I'm dealing with the same issue myself. Apparently I've had a gimbal issue which I always thought was simply normal operation. (The gimbal makes a high-pitched sound and vibrates during certain motions). Just the other day I went to the DJI website to start a service request and when I entered my Phantom 3 Pro's SN the DJI service system identified it as a Phantom 3 Advanced. However, when I used a different SN "decoder," it correctly says my craft is a Phantom 3 Pro. Very curious. I should say, too, that I no longer have the retail box for the Phantom, and the SN sticker under the battery compartment does NOT appear to have been tampered with.
Here are the links of the two systems I used:
DJI's Online Repair Request System
DJI Serial Decoder
I look forward to hearing if there was any resolution with your situation. Thanks! |
