Replaced new camera, Phantom beeping
Mr Smith
Flight distance : 3621066 ft
So I replaced the camera on my friends Phantom 3 Advanced after he crashed it, but I am now getting a loud consistent beeping as you can hear in the video. I tried doing a firmware update with the latest Phantom 3 Adv firmware from Dji's website, but I don't believe this solved anything. One of the small cables that connects the gimbal to the main board is flattened a bit, and I'm wondering if that has anything to do with the beeping.
The remote is updated with the latest firmware, but attemping to update the aircraft doesnt seem like it did anything. I tried updating it by inserting the micro SD card in the gimbal, and I let it sit for about 10 minutes, but there was no change in the gimbal beeping and only the typical latency with the drone beeping. It is also saying "No image transmission signal" but I clearly have a good video feed that isn't laggy or green screening. Check out the picture at the end of the video and let me know if you think that cable is the problem, or if there may have been some other problem/disconnect due to the crash.
Thanks!
2018-3-4
DJI Susan
Hello Smith, I'm afraid that the firmware will not be successful if there is any hard glitch. Please kindly send it in for a full diagnosis: https://www.dji.com/support
2018-3-5
ALABAMA
Flight distance : 10442687 ft
Even small dents in the cable can indicate damage to wiring.  I would have it replaced.
2018-3-5
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Re-flash the full firmware.
2018-3-5
Spacetrakker
Flight distance : 115384 ft
Reflashing the firmware just introduces another red herring!
The aircraft crashed and damaged the camera and possibly a cable. A crash will not damage the firmware so why complicate the troubleshooting by introducing new variables?
2018-3-15
PowerBand1
Spacetrakker Posted at 2018-3-15 05:22
Those flattened cables should still work...the beeping is regarding the software update. Try reformatting the sd card and restart the phantom.
2018-3-15
PowerBand1
PowerBand1 Posted at 2018-3-15 05:46
you may have to wait 5 to 10 mins for beeping to stop.
2018-3-15
Mr Smith
After watching a video on how to flash the firmware (by holding down the linking button as you turn on the drone) I was able to get everything back to normal. the drone is now flying as it should and everything seems to be ok!
2018-3-15
Spacetrakker
Mr Smith Posted at 2018-3-15 11:06
Good job well done !
2018-3-15
