Barry R
Flight distance : 2077 ft
Geebax Posted at 2018-3-9 18:31
OK. The problem you are seeing has a rather poor name, it is called jello effect, and is caused by the camera being vibrated. You might try another set of props if you have a spare set, or at the very least, check out the ones that are fitted for nicks or lumps missing. If you find a damaged prop, throw it away.
If that does not cure the problem, then the problem is going to be a bit harder to solve.
Hi Geebax
I have read and "u Tubed" everything I could find on the jelloing problem. As a consequence, before setting the repair experts onto the gimbal and camera, I am going to balance the props, video at lower ISO and shutter speeds and avoid strong winds where possible. Several Tube sessions suggested flying in "A' rather than "P" mode when videoing in order to remove the GIS and hence reduce the myriad inputs to the copter system. As a novice I like the "P" mode safety factors for hovering and RTH.
I envisage taking off in "P"mode and alternating between "P" and "A"during flight then checking the clips to ascertain if there is improvement or otherwise in the two resulting video qualities
After the above diatribe, my question is, can I simply change between "P" and "A" modes during flight?
My apologies for using up your time.
Regards
Barry |
