Message "please connect with dji camera" prevents me from flying
6852 14 2018-3-5
cs_
Switzerland
Hi all
I‘m currently struggling with a message in DJI GS Pro which I could swear was not there last week: In the preflight check, the app tells me that there is no DJI camera connected, and prevents me from flying the mission. I have an external camera attached which is triggered by the DJI remote start/stop. This worked fine till today, I did exactly the same mission last week, successfully. Sure, there was always a warning, but in the form “no camera found or external camera attached”, which did not prevent me from flying. The only that is different from last time is that I had to exchange the iPad mini 2 where GS Pro is running on. What am I doing wrong? Is there a setting somewhere where I can force camera triggering even if no camera is recognized by the M600 Pro?
Cheers
cs_
2018-3-5
DJI-Mark
There is not a way to force a camera connection. Can you double check to make sure that gimbal is properly installed? What type of camera are you using? Please send me a personal message on this point.
2018-3-5
a.richardson
The latest version of GS Pro is now preventing take off without a DJI camera connected to the UAV for all new flight plans. This is an issue for all DJI Matrice series users who are used to connecting non-DJI cameras to the UAVs. Previous versions of GS Pro allowed the use of any non-DJI sensor (whether it was connected to the UAV or not). This was highlighted by the ability to create a 'custom' camera in the camera drop down menu. If a DJI Developer can comment on whether or not this change will be rolled back to allow custom sensors to fly, or whether all flights using GS Pro will require a DJI camera to be attached, that would certainly be appreciated by the community using the software who believe it is a good product. Otherwise, another flight planning software will need to be used.
2018-3-13
cs_
Switzerland
Hi all,
Sorry for the late answer, I finally found out what was wrong some days ago:
  • if you choose PhotoMap as mission type, the M600 won't start without a DJI camera attached
  • if you choose 3D Map Area as mission type, the app allows you to ignore the missing / not detected camera and fly!
The parameters in the two mission types are exactly the same, that's why it took me ages to realize I choose the wrong mission type...
In 3D Map Area mode the flights work like a charm - the only thing that bothers me is that there is no follow terrain mode in DJI GS Pro, but I have to stick to it, its still the only app I know that can trigger my camera using the remote start/stop module...
Cheers
_cs
2018-4-3
dronie326
Flight distance : 810 ft
cs_ Posted at 2018-4-3 11:19
Hi all,
Out of curiosity what camera are you using?
2018-4-9
3nzo
Flight distance : 104180 ft
dronie326 Posted at 2018-4-9 11:17
Help! I have the same problem witht he greyed out "Start to Fly", but unlike the suggestion above, I get stopped in both 3D Map and Photomap modes with slightly different message.  This is an Inspire 2 with a third party NIR camera.  I hope this behaviour can be changed!  We can use the Waypoint mission, but then we have to design our own flightlines, which is hardly optimal.
2018-5-1
Xer
Chile
Help please!
i have a phantom 4 advanced
when trying to make a flight as usual, it does not recognize the camera or the sd card, it asks me to connect a dji camera.
before the update of the application I never had problems to make the flights, I really need help please.
I have not changed the camera, it works without problems in the application "DJI GO 4" I have the problem only with GSPro
2019-1-5
Xer
Chile
Help please!
2019-1-5
ismac
Argentina
Xer Posted at 1-5 11:14
Help please!
Hi, I have the same problem with phantom 4 A. Did you solve it?
2019-1-9
Keule
Flight distance : 3733015 ft
ismac Posted at 1-9 17:05
a new version 2.0.2 of GSPro is released (Jan 10, 2019)
Fix: Phantom 4 Advanced Camera could not be recognized
2019-1-10
ismac
Argentina
Keule Posted at 1-10 00:39
Solved, thank you
2019-1-10
ismac
Argentina
Solved, thank you!
2019-1-10
UAVServices
Flight distance : 756178 ft
Yes we have the same problem with A3 controller... it now has a red X when trying to plan a mission without a DJI camera... DJI this is  a major issue your response is needed ASAP
2019-3-6
MajorsMavic
Flight distance : 4166627 ft
Mauritania
Hi all, I am having the same issue. I have an M600 pro and a geoslam ZEB point cloud camera. In the GSP app everything is okay untill it checks for a camera. The Geoslam camera is only mounted onto the frame of the m600 and not connected with any wires or into any ports, they are working independently of one another. I need to know how to bypass the camera function in GSP so I can just do a standard grid flight while the geoslam camera does its own thing.
is this possible. DJI please help.
cheers
2019-12-2
ddraun
Hi!
I added a custom camera to fly with an Altum attached to Inspire 1. During the preflight checklist it says Camera "Not connected" which makes the flight impossible. I am using 3DMap Area mission as suggested.
Could you please help with this issue?
Thanks a lot in advance!
2020-2-23
