epensenstadler
Hello, not sure if you still need help here, and it didn't look like your question was directly answered, so I hope this helps:
I ASSUME you are referring to the one screw that is under the mother board. If so, then you have to remove the silver unit that is above it - it appears as though this silver unit is securely attached to the motherboard, but actually it is only held on by very strong double sided tape. The LIGHT use of a flat head screw driver will help you to pry it up. Once this is up, and all the other screws are removed, then you will be able to physically reach that one seemingly-impossible-to-reach screw!
Hope this helped!
Eric |
