RicardoGray
Flight distance : 4356421 ft
Matts4 Posted at 2018-3-6 03:42
Hey thanks for response. Ya it took a hard landing and the gimbal hasn't worked since. The gimbal doesn't repond at all. The camera itself is working fine though as I can see on the app. Any suggestions? Thanks!!
Try checking and looking at all of the ribbon cables, etc. Ensure they are properly seated into their respective sockets. You can easily slide those damper bushings out of the holes and lower the whole thing to see on the back of the gimbal assembly. Also check that ribbon on the gimbal itself. It actually plugs into a couple of places. You may gave to remove a cover to inspect it. Good luck. |
