S1000+, A2, Lightbridge with Futaba 14SG
2253 5 2015-5-4
cspan21
I just purchased a Futaba 14Sg looking to get it setup and working with lightbridge. Are there any settings that have to be changed in the futaba or just setting up the channels?\
Thanks
2015-5-4
smee56
Flight distance : 18655 ft
Setting up the channels are fairly straight forward, it is a pain to jump between the programs to ensure everything is working properly.
Have a look at THIS, i wrote it up as i found no helpful setup plans/tips anywhere.
2015-5-4
jorgeyutronic13
Chile
hola and install the DropSafe + ligthbridge? Gimbal  GH4HD + A2 + S800 evo
2015-6-18
smee56
jorgeyutronic13 Posted at 2015-6-18 23:46
Of course i would like input from others but as afar as I am aware the answer is no.
You could run it off a second TX/RX but the you would loose the automatic deployment function.
2015-6-21
contact
Flight distance : 211312 ft
Hello, I am flying an s1000+, A2, gh4, and light bridge and I just installed the dropsafe. Ground test seem perfect but the real test is in the sky, right?  Happy flying
2015-6-30
FirstFlight
contact@flyhigh Posted at 2015-6-30 06:42
Hello, I am flying an s1000+, A2, gh4, and light bridge and I just installed the dropsafe. Ground te ...
Isn't there a conflict between the programed logic of the A2 in the event of an engine failure and the use of the drop safe system?  I thought the A2 detects a engine failure by detecting a amp spike, then would shut down an engine on an opposite arm. The pilot could reasonably recover the UAS to the ground.  With the logic of drop safe, all engines would shutdown and chute will deploy.  The UAS will crash (even with the chute) and ultimately suffer severe damage.  No?
2015-9-5
