CanonMax
Flight distance : 8953215 ft
Until the last DJI GO 4 App Update (iOS v 4.2.6), when looking/checking flights in the app you could check "standard", "Satellite" or "Hybrid" for the map which shows the flights.
This preference was kept until the next time you wanted to check or look at a flight. Even when you quitted this DJI GO 4 app.
I noticed that this preference is NOT present anymore and that you need to select and re-select EVERY time which map you want when you look at your flights. Even within the same session, unless you use the < of > to go to the previous/next flight.
I thought it was a GOOD idea to keep the selected preference. Maybe the engineers can have a look at this phenomenon....
I just checked the DJI GO App (v 3.1.28) ... here it still keeps the preference you select...
Thank you |
