Course Lock Tap Fly
2355 32 2018-3-6
hallmark007
Flight distance : 8673241 ft
I know at the moment we don’t have course lock on Mavic Air , I know it’s a real favorite with some, but doing a small bit of testing today in Tapfly I discovered a work around that might suit those who need course lock.
Put Aircraft in Tapfly, use free fly mode you can pick a spot to fly aircraft tap go and just use yaw and ascent or descent your aircraft will hold the line you first set and you can turn aircraft 360 while aircraft flys perfectly straight towards your target, it works pretty well.
Hope it might help some.
2018-3-6
sky6105
Flight distance : 345653 ft
I am always looking for a reason to go fly and try something new.
Thanks
2018-3-6
hallmark007
sky6105 Posted at 2018-3-6 10:23
Thanks
You should be able to get really good cinematic video using this method.
2018-3-6
Montfrooij
Flight distance : 2438094 ft
That is an interesting method.
If you have some footage already, please share
2018-3-6
hallmark007
Montfrooij Posted at 2018-3-6 13:35
I don’t have any footage just discovered today while doing a bit of testing, next time I go out I will try it incorporate it into some footage.
2018-3-6
Montfrooij
hallmark007 Posted at 2018-3-6 13:51
I think you might be on to something I considered as an omission in the MA capabilities, so I am curious!
2018-3-6
LoSBoL
Flight distance : 271650 ft
Interesting, yet another thing to discover, thanks
2018-3-6
DJI Susan
Nice tip! Thanks for sharing with us.
2018-3-11
A CW
Flight distance : 13838848 ft
Hi Hallmark - is this the equivalent of 'tap fly free' on the P4P - thats a good mode to have on the MA if so. Does using it also switch off the obstacle avoidance too?
2018-3-11
hallmark007
A CW Posted at 2018-3-11 02:10
Yes no obstacle avoidance, I find using P4Pro that using Draw mode works really well and does a similar job, Draw mode is a really good feature much underused in Draw you retain obstacle avoidance but still have stick control . Maybe we will see it come to Mavics in the future.
2018-3-11
LoSBoL
hallmark007 Posted at 2018-3-11 02:42
I haven't tried yet, and when selecting the free mode you should keep an eye on your flight path for AO, but it should work.
2018-3-11
hallmark007
LoSBoL Posted at 2018-3-11 02:54
[view_image]
Slightly different in P4Pro.
2018-3-11
LoSBoL
That's progress I guess.
Either way, better not rely on it when in free mode, you can yaw your drone into anything if not mindfull.
2018-3-11
hallmark007
LoSBoL Posted at 2018-3-11 04:08
Well if using method above you would be flying sideways so OA won’t help you, but I have to say this method works really well being trying it out this morning well impressed, there’s always more than one way to skin a cat.
Fly Safe.
2018-3-11
ro_flyer
Flight distance : 7557283 ft
Brazil
This makes really cool paralaxe shots
2018-3-11
hallmark007
ro_flyer Posted at 2018-3-11 04:57
You can get two really nice different lines of sight and flying is very steady.
2018-3-11
hallmark007
Montfrooij Posted at 2018-3-6 14:13
Just a quick clip shows the idea really easy to work , ignore the quality it’s straight off the app.
2018-3-11
A CW
For sure - Draw is a great mode to use on the P4P. Glad to see tap fly free is on the MA - that is also a great feature to have.
2018-3-11
LoSBoL
A CW Posted at 2018-3-11 06:17
I still find it amazing. I remember the first time I saw a shot like this. It was about 15 years ago alongside a Formula 1 track.
It was then super expensive and needed cranes and tow cables for it to work.
Now a 800 dollar drone can do this trick.
2018-3-11
PedalingDuo
Flight distance : 31896 ft
Here is a good tutorial an tap fly.  I found it on YouTube
2018-3-11
hallmark007
PedalingDuo Posted at 2018-3-11 06:47
Tap Fly Tutorial
Good job thank you.
2018-3-11
Montfrooij
hallmark007 Posted at 2018-3-11 05:56
https://youtu.be/2VAbZ1qV5r0
Thanks for that.
Now it won't be easy, but I think it is possible.
What kind of stick movement are you making?
2018-3-11
hallmark007
Montfrooij Posted at 2018-3-11 10:28
Thanks for that.
Just a simple yaw left or right once you yaw to a position it will hold that position and aircraft will stop just before your setting for tapfly .
2018-3-11
Montfrooij
Tap Fly Tutorial
Yes, that looks great.
I am curious with the free mode if you can use your sticks or have to use the screen.
2018-3-11
Montfrooij
hallmark007 Posted at 2018-3-11 10:33
And can you use the sticks for the yaw motion while flying?
Or do you have to use the screen?
2018-3-11
hallmark007
Montfrooij Posted at 2018-3-11 10:44
Yes you only use sticks, first you can see in the video I set a point to tapfly to the aircraft holds this heading controller only needs to operate yaw movements, he can also Move gimbal up and down.
2018-3-11
Montfrooij
hallmark007 Posted at 2018-3-11 10:47
Very nice. That will be much more smooth.
To my best knowledge this is not in Mavic Pro or Spark right?
2018-3-11
hallmark007
Montfrooij Posted at 2018-3-11 10:52
No not yet.
2018-3-11
Montfrooij
Not that Mavic Pro needs it with Course / Home lock, but Spark could use the free mode I think!
2018-3-11
fansd26b9eea
COURSE LOCK in the mavic air
Thanks for answering, but I think  that  tap fly is a bad way to control the correct direction to film an object.
Dji will not install the COURSE LOCK in the mavic air . All cheap  toy drones as Hubsan H502S have the headless mode (Course lock).
In Tap fly you always must pay attention not not to fly against an object. I hope in the future it will be in your app 4.
sorry for my bad English. Tere are so many years that I learned  it at school. Hi your hotte.surf
2018-3-28
hallmark007
fansd26b9eea Posted at 2018-3-28 06:46
I don’t know if dji will install course lock, but my method of substitution is a workaround so it may require better piloting skills but will give same results, we will just have to wait and see.
2018-3-28
Hestia
Flight distance : 135381 ft
The Air is my first drone and I use TapFly really often when filming! What was the course lock from the other drones?
2018-3-28
hallmark007
Hestia Posted at 2018-3-28 08:19
This will best explain course lock.
2018-3-28
