HereForTheBeer
Flight distance : 5381368 ft
Alex B. Posted at 12-27 17:56
What’s your device and app version?
Have you tried downgrading the app version to see if that helps? Have you tried in a different location, an empty huge field or on the beach or out to sea are good options.
i have a bit of biased especially since my crashed proved my point about dji needing to fix wifi system and add channel hopping/sniffing and splitting channels/bands.
wifi makes it hard to fully prove with what does and doesn't work without doubt in the real world seems to work, as wifi is "friendly" connection standard meaning its designed to not want to overlap or talk over other devices and take turns whenever possible..but there is a few issues..almost everything in modern age uses something on same bands or connected to wifi and is defeating "friendly" logic.. smart speakers, TVs, security systems, cameras, lighting, smart meters and cars even have hotspots in them now a days.. so on and so forth.. add that plus bunch of homes around you likely doing similar stuff... flying around a typical neighborhood, all it takes to go from smooth 720P 30fps live viw to laggy frame dropping mess is someone down the road flipping their smart lights on or off..
as for theory of trees and buildings causing wifi interference, that's wrong, technically..(speaking to hallmark's remark) the term looking for is called attenuation because not very much output coming from trees or buildings that competing with EM spectrum.. but rather trees and buildings are slightly reflective/absorbent and change signal behavior as well as signal propagation. but yes and its unacceptable how dji allows the drone in these cases to drop frames for so long before drops resolution.. i sometimes lost live view for 1/2 second (frame drop/lock around some really thick large trees im flying around before frames drop and another half second before resolution drops.. no reason should take that long.. |
