Aardvark
Flight distance : 384432 ft
ANDRÉ RICARDO Posted at 2018-3-13 04:57
Susan yesterday I flew in other place and the problem appear one time only. Like I told you this problem appear and disappear quickly between 2 - 4 second. Yesterday night I done a downgrade on the aircraft. I already done test also. I flew with two battery and the last one appear one time only.
There's nothing on top of the aircraft is there ?
The GLONASS/GPS receivers are mounted at the to of the aircraft just under the DJI sticker. Anything on top of that can block these signals.
If you've tried flying in different locations (in open areas), tried different firmware and refresh/factory resets and still getting the problem then I would return for repair. There could be a loose connection to GPS/GLONASS receiver.
If you're flyig in forested or mountainous areas then it may be usual to lose satelitte reception more easily.
