photogaff
Flight distance : 274472 ft
DJI Thor Posted at 2018-3-8 01:10
Hi Gaff, is there an error message when you were able to press the pano option? There might be some factors which lead to the failure of the pano capture: the drone is moving, sticks are moving to quit, height/distance limitation, the gimbal is stuck, the gimbal is moving and insufficient space and so. Please check if you are in one of the conditions. If it doesn't simply work, it would be nice if you can provide me with a video of the operating procedure, I would like to check. Thank you.
Hi Thor, thanks for getting back to me on that. I do recall seeing an error message saying "not permitted" or something to that effect. I'll have to try and reproduce the issue and show you some definitive information - however it struck me as odd given that it had occurred while no external factors could have interfered with the operation (no winds, no stick movements, not in sport mode). While I could video perfectly, I just couldn't operate a panoramic. Move it indoors, and it worked (involving no change of settings).
I'll try get more conclusive documentation for you on that. |
