Issue with Pollar Pro filters
2176 21 2018-3-7
Vasco
Flight distance : 5427717 ft
Greece
[size=14.666666984558105px]I just bought a set of Polar Pro filters for my mavic pro. Unfortunetly it seams that when it is installed and during star up procedure and gimbal initialization the filter is quite big and lens stock on gimbal bracket . As a result i got gimbal motor overload error.
[size=14.666666984558105px]Any suggestion ? Is this normal !!!!?
[size=14.666666984558105px]I have also Sandmark filters which are a lot  smaller and didn't have any issues with these!!!!
[size=14.666666984558105px]Please advise
2018-3-7
chiplifter
Flight distance : 745180 ft
I use polar pro filters too, never seen this error. Ok, I once saw this error when I forgot to remove the gimbal cover. Can you send a photo of the installed filter?
2018-3-7
Vasco
Greece
chiplifter Posted at 2018-3-7 05:32
2018-3-7
Montfrooij
Flight distance : 2560453 ft
That looks very different from my polar pro set.
2018-3-7
Montfrooij
https://www.polarprofilters.com/ ... ries-filters-6-pack
2018-3-7
Cameleon
Flight distance : 60394 ft
Think I remember reading the first batch of PolarPro filters had to be installed after start up. They made newer and lighter ones which meant they could be installed before start up. Not sure which of these you have there.
2018-3-7
Vasco
Greece
Cameleon Posted at 2018-3-7 06:01
2018-3-7
chiplifter
What kind of Polar Pro is that? Never seen it.
2018-3-7
chiplifter
that is the same set I have (the gold ones).
2018-3-7
Montfrooij
chiplifter Posted at 2018-3-7 06:27
That one works perfect (at least with my MP)
2018-3-7
chiplifter
Montfrooij Posted at 2018-3-7 06:30
[Off-topic] I just got them recently. Now figuring out best color profiles and camera settings. ;-)
However, I don't think there is a 'Best' setting but improvements can always be made.
2018-3-7
Jos A
Flight distance : 73209 ft
chiplifter Posted at 2018-3-7 06:37
there is the polar pro app on android to calculate which filter
2018-3-7
Vasco
Greece
This don't make sence!!!! How do they sell product that is not working properly 100%!!!!! And we are talking about Polar Pro!!!!! Not a no name brand!!!
2018-3-7
The Farmer
Flight distance : 165495 ft
Vasco Posted at 2018-3-7 07:33
Vasco, I just purchased that same set of filters for my MPP a couple days ago and have had no gimbal errors when using them. Just make sure they are pushed all the way on. If they are, then I suggest contacting Polar Pro and see if they have suggestions.
2018-3-7
Vasco
Greece
The Farmer Posted at 2018-3-7 07:45
Thanks for your reply. I try to install and reinstall several times with no succes .... Anyway i have contact with Polar Pro and waiting for their reply
2018-3-7
chiplifter
Jos A Posted at 2018-3-7 06:50
Ok thanks. I downloaded it. Pretty handy. Only I can't select 25 fps what I am used. Probably do the math with 24 fps.
BTW: I went out this afternoon to film a bit and do some tests because it was nice and sunny. Bummer, when I arrived at the location it became cloudy (total overcast) and to dark to use filters.
I did some fun flying and then got a disconnect from my phone. Phone was total unresponsive (lifefeed stopped and greyed out).  Even restart from phone and cable reconnect did not work. Also tried litchi, also no connection. Controller still had connection with the mavic.
I flew her back, by watching the 2 red headlights pointing to me (after shutting down video recording!). After landing I restarted the RC and phone connection was working again. Same thing happened 2 or 3 days ago.  Then, after landing  I powered down and up the AC resulting in a reestablished connection.
No fun flying in the dark. Another reason why everyone always should fly in LOS.
Last year this never happened not a single glitch.
2018-3-7
Jos A
Litchi and Go app can't work together, you have forced closed the app and delete default settings.
2018-3-7
chiplifter
Jos A Posted at 2018-3-7 10:54
I know and that is what I did. Since go 4 did not respond anymore I force closed it and started Litchi. I even shut down the entire phone and started Litchi, also no connect. Only after powering down the RC or the AC the apps on the phone could connect  again.
2018-3-7
Montfrooij
Yes, that requires some practice and testing
2018-3-7
Montfrooij
They do have good customer service, so I would try with them.
2018-3-7
Vasco
Greece
Montfrooij Posted at 2018-3-7 22:42
Thanks for your kind reply. I have contact them and it seams that in older filters some problems with contact filters with gimbal during initialization has been reported. Most probably they will replace them with newer
2018-3-8
Montfrooij
Vasco Posted at 2018-3-8 05:38
You're welcome and hope you get it sorted out
2018-3-8
