New Phantom 4 Pro/Pro+ Firmware Released (08/03/2018)
1234Next >
38275 132 2018-3-7
Nelsonlee
Flight distance : 2779203 ft
Malaysia
I have done updated this latest firmware on my Phantom 4 Pro with latest DJI Go 4 V4.2.6 Android (Samsung Galaxy Note 8) but haven't go for the test flight because the DJI Go 4 apps still having a BUGS! when i click on select channel default setting is (AUTO), after i click to (MANUAL) select 2.4G or 5G it can but does not have option to give you select channel (1,2,3,4,5,6,7,8,xxxxx)!!!
Now on my DJI Go 4 apps only can click to choose 2.4G or 5G only!
2018-3-16
AlexVideoShark 5
Flight distance : 4522884 ft
Nelsonlee Posted at 2018-3-16 06:39
Interesting
thanks for your exposure ...
I do not know if this is normal, dji could have setted this way ... but I don’t think so ...
maybe you should try again a second time ... re-update everything through PC. ..
my experience in a previous update,  has done the same thing with me ...
via dji go, after the update I had noise in the gimbal ...so
after updating everything with dji assistent a second time... everything worked well ...
so I'm not sure if this was it, but I think it's better to try ...
what do you think?
Anyway... thank you again
2018-3-16
skywatch111
Flight distance : 8677251 ft
Russia
I've updated latest 5.0600 firmware today via DJI Assistant 2. Tried to fly but can't see anythig on the screen (for DJI admins: Latest firmware, latest DJI GO, iPad Mini4 with latest iOS) What I'm do wrong?
Send best regards to DJI coders (some epic music from DJI lib to show epic fail)
2018-3-16
CraigR
skywatch111 Posted at 2018-3-16 13:55
https://youtu.be/zNB_a7IY21M
Wow. That's crazy.
They should git bisect the issue but maybe they don't use source control and have no idea what they broke in the last update (and the fix that judging from your video makes things even worse)
2018-3-16
Grumpybeard
Flight distance : 593356 ft
Switzerland
Thats shocking @Skywatch111 - as workaround have you tried turning off video cache and lowering video bit rate?
2018-3-17
Rocher Bros
Flight distance : 1322257 ft
Dublinphantom Posted at 2018-3-12 01:58
Updated and tested and no problems at all that I can find anyway. Hopefully none will arise.
No vibrations before taking off on the aircraft?Which Phantom you have the Pro or the Pro+ and if you own the Pro what device you use to the RC?
2018-3-17
Rocher Bros
Try to do a ram reset to ipad mini 4 before using it i have the same issues and that seems to work for me...
2018-3-17
skywatch111
Russia
Grumpybeard Posted at 2018-3-17 03:36
Yes, I did it first. The same result
2018-3-17
skywatch111
Russia
Rocher Bros Posted at 2018-3-17 04:37
Try to do a ram reset to ipad mini 4 before using it i have the same issues and that seems to work for me...https://www.youtube.com/watch?v=1PZtqFm-HlQ
Thank you for your advice!  I'll try and reply here.
2018-3-17
JohnGrant
Flight distance : 174921 ft
I’ve updated Phantom 4Pro, Remote and DJI Go 4 Software.
I took the aircraft out the next day and flew with no issues.
I flew line of sight 400 metres away and used Return To Home. Height was set to 100 metres.
Phantom landed within 15cms of take of point and although the home point was recorded I didn’t tick ‘precision return’
Tested in normal and sport mode.
Very happy
Used iPad Pro 256gb WiFi only
2018-3-17
dorbot
Flight distance : 844770 ft
Updated yesterday, Flew for One battery. Not an exhaustive test, I know, but no problems to report apart from cold feet and fingers!
Tested with, Ipad 2017 32gb wifi/cell.  iOS 11.2.5
2018-3-18
Grumpybeard
Switzerland
Thanks for testing and updating here dorbot - what iOS firmware you have on iPad?
2018-3-18
KedDK
Flight distance : 1133038 ft
Denmark
Just wondering, do you scroll down to the bottom after you have selected Manual?
I have myself been confused tapping the channel numbers until i remember to scroll down to find the new part of the screen that become visible when manual has been selected ...
2018-3-18
KedDK
Denmark
Genghis9 Posted at 2018-3-8 11:21
Has anyone had any results up or down?
I only had a few flights but have seen no new issues.
If the constant High Wind warnings was relaxed in .300, i didn't see it in the few flights i did on that version,  for sure that is back in .600.
Also i have had some movies with disturbing small white spots and some with black spots, but i think the FW is not to blame for neither a sudden snowfall or flock of birds entering the scene ...
2018-3-19
S.D. Pilot
Flight distance : 10278435 ft
Genghis9 Posted at 2018-3-14 20:29
Have you had a chance to fly yet, if so issues?
I happy to report that with the recent update FW installed, yesterday I flew a total of 3 batteries and all checked out fine.
No signs of the camera image inverting at all. Thank goodness.
2018-3-19
Timinator
Flight distance : 3481985 ft
This has all the hallmarks of shooting in 4k with a slow memory card.
2018-3-19
allyssongemelli
Flight distance : 2562467 ft
Brazil
I have a doubt if for the Phantom 4 Advanced is not necessary this firmware? Or will don't show anyway.
2018-3-19
skywatch111
Russia
Timinator Posted at 2018-3-19 05:15
I use SanDisk U3 fast card, it writes smoothly 4k 60fps. Everyting was ok before I upgraded 5.0600
2018-3-19
Timinator
skywatch111 Posted at 2018-3-19 10:33
Yup - that card should work ok.  I wonder if it was buffering issue within the fimrware causing the same effect.
Just do rule out a coincidental failure, do you have another card you can try?
2018-3-19
skywatch111
Russia
Timinator Posted at 2018-3-19 10:57
I tried  3 different cards, including Sony 16 Gb from drone package. The same picture.  And more, I tried another iPad - the picture did not change.
2018-3-19
Timinator
skywatch111 Posted at 2018-3-19 12:24
Time to revert to your previous firmware.
2018-3-19
Genghis9
Flight distance : 961 ft
KedDK Posted at 2018-3-19 02:33
Thanks I would certainly like to see those warnings tapped down so as to be more believable...
2018-3-19
Genghis9
S.D. Pilot Posted at 2018-3-19 04:29
OK good to know, looks like I'll do the update as I don't like that inverted camera thing it is extremely unsettling and I'd very much like it gone!
2018-3-19
Grumpybeard
Switzerland
Did you do the update Genghis9, how did you get on?
2018-3-20
DeputyDawgAtl
Flight distance : 1507073 ft
I updated my P4P to the latest: V 01.05.0600
No apparent issues when flying.  I did notice when I turned right and left the gimble had a very slight hesitation.
Perhaps that was a setting that got over written OR I never noticed
One thing for sure, getting pics from SD card to Ipdad Mini is MUCH SLOWER.  Used to transmit approx 1mb a sec or more.  Now it barely gets 500mb a sec.
Anyone else experience this?
2018-3-24
AlexVideoShark 5
After the Firmware update: V 01.05.0600
Phantom 4 Pro + IPad Pro 9.7' data+wifi last update
taste of spring  --  castle on the seaafter 3 battery fly (only), looks like all fine . -
back home properly , no vibration , panorama mode , ... all are working correctly
2018-3-24
KedDK
Denmark
Just noticed that a new version of DJI Assistant 2 has been released in the P4P download section a few days ago.
What's new one might wonder, well a Battery update fix for the Mavic Air, wow that makes me happy ...
Anything else, oh Phantom 4 Pro Firmware: v 1.4.602, what gives this version was replaced by 1.5.300 on the 25th of December 2017 and 1.5.600 on March 8 in this thread, DJI when are you going to get the things right?
Please provide us with information that make it look just a little like you know what you're doing.
2018-3-27
Farmer_mapo
Flight distance : 878373 ft
South Korea
firmware : V01.05.0600
djigo4 : 4.2.8 (ios)
issue: white balance error
When WB manually set, the color temperature (K) will differ by about -700, So the color is cold.
Ex: When set to 5400K, Actual is taken at 4800K
set to Auto WB in daylight, the color temperature (K) is lowered.
This error affects both the picture and the video.
Please fix the WB error as soon as possible.
2018-3-27
alexo
Flight distance : 70866 ft
I'm not happy with this release, orange photos issue has been resolved which is good however this has come at the cost of very frequent app crashes, the green patching on the video and the CPU overload errors and hot ipad.
My first app crash was within 1 minute of take off while in initial hover I checked the settings and took a photo to verify that camera was good and the app crashed.
This is Phantom 4 Pro, Ipad mini 3 with latest firmware, IOS and no other apps on the Ipad and cold booted and lots of free RAM.  I will try to fly without video cache tomorrow.
I love this aircraft and camera but I hate the software bugs in core inflight features.
What alternative apps do people recommend?
2018-3-29
AlexVideoShark 5
alexo Posted at 2018-3-29 22:10
I use an Ipad 9.7 pro wi-fi and data
there are a lot of apps installed, some even running in the backround
I updated the phantom 4 pro with the iMac, through assistant
DJIGO 4 updated
Ipad updated ... in short, I try to keep everything updated ...
the Drone works all right (always with crossed fingers) ...
I also forget to reset the ram on the ipad ... as someone suggests ...
so I suggest you double check everything, maybe you need to install the iOS on the iPad again
same suggestion for the Phantom firmware
let me know ... because I believe, that it is better to try
happy easter
2018-3-31
w0lfy_
Romania
I've just updated to V 01.05.0600 using the DJI Go APP and so far all seems fine (short flight indoor).. I will fly the drone tomorrow and return with more feedback.
2018-4-4
Wazdog
Flight distance : 146877 ft
All I can say is that I hate DJI and their crap products with the passion, the service is non existent, the product never works properly in a straight forward manner and well I could keep going on. I hope another company comes out with (if not already which I haven't discovered yet) a better product then I'll enjoy doing a burn out on my Phantom 4 pro plus , watching it's cheap plastics and all sorts of stuff fly all over the place... Gee that was hard to restrain from swearing...
How can they not create software that works properly with their own product which they should know inside out? The mind boggles..
Thanks for reading, I hope this made you feel better. It certainly did for me.
2018-4-6
KedDK
Denmark
Wazdog Posted at 2018-4-6 22:59
I am very familiar with that feeling from start to end ...
2018-4-7
KedDK
Denmark
w0lfy_ Posted at 2018-4-4 02:47
Did you get to any conclusions yet?
2018-4-7
nJo-nJo
Flight distance : 51355 ft
Bulgaria
You must switch off AC when change band an channels to work...
2018-4-7
fansf4b02c46
I am having p4p+ done with updates through interconnecting RC and aircraft by WiFi, but I have 3 batteries so what should I do to updates rest two  batteries
2018-4-7
Nelsonlee
nJo-nJo Posted at 2018-4-7 09:29
2018-4-8
KedDK
Denmark
Sorry for my ignorance, but i am not used to zebra moods and wonder what that reply tell?
is it happy because the suggestion from njo-njo helped you or is the zebra about to fall out dead of laughter due to a far out suggestion?
2018-4-8
KedDK
Denmark
fansf4b02c46 Posted at 2018-4-7 10:17
You will find it gives itself, if update of the batteries is needed you'll see something about a firmware mismatch, then just tap the update and follow the prompts.
2018-4-9
GaryQuintrell
Flight distance : 6752 ft
Hi i have a problem with some images in raw coming out almost as they are like the old school negatives?? can you please help as i use the images professionally
2018-5-1
1234Next >
