Grumpy Old Man
Flight distance : 37795 ft
DJI Thor Posted at 11-5 03:16
I am sorry for the inconvenience. If it is convenient, please check the current version of the controller and see if it is 01.04.03.00, if it is not, you can download the latest version for the controller here https://www.dji.com/sg/downloads/products/phantom-4-pro and check again.
If the issue persists after trying to fly in different locations, you can send both the drone and controller back for further analysis.
Please click https://www.dji.com/us/service/repair to start an online repair case.
The controller is the latest firmware, and I did a factory reset after installing. Both the drone and the controller are the latest. It was working perfectly right up until I did the latest firmware install then it turned to rubbish.
I have flown the drone at many different locations and every location is exactly the same. Even outback Australia.
The 5.8GHz channel reports no signal until I fly 500 metres away, then it reports a signal. If I fly closer than 500 metres it reports a loss of signal.... it is totally screwed up. If the drone is one metre away, no signal, 500 metres away, full signal. That's not hardware fault, that's firmware issues. |
