Ronin-M RC ISSUE
4689 19 2018-3-8
InterStellar
Philippines
Hello Dji,
When I'm using the Ronin-M RC and trying the pan, tilt, roll axis it always stop in some points like in this video.
Ronin-M Reciever firmware: 1.1.0.15
Ronin-M RC firmware: 1.1.0.20
RONIN-M RC
RONIN-M RC
Questions:
- Is there any fix for this?
- Can I downgrade my Ronin-M RC firmware?
Thanks in advance.
2018-3-8
Ale_Zakko
SAME MY ISSUE!!!! As you can see from the official release note, the correct firmware should be 1.1.0.21 but i can't upgrade the transmitter firmware from the old 1.1.0.20 ...
I need to use the Gimbal with the second remote operator next week and i don't know how to fix this issue!!!
2018-3-8
Ale_Zakko
EDIT: as you can see, the transmitter works well only when the bind led it's green. When it's red everything stop...
2018-3-8
Ale_Zakko
After forwarded the issue to dji support, a good people help me, and solved my problem. Now everything works well! I confirm that the issue is located in dji assistant that doesn't allow to upgrade the transmitter firmware to 1.1.0.21. now everything it's OK!!!
2018-3-9
djiuser_TkHM7OrpM5mA
Colombia
Great, what's the trick to fix that issue @Ale_Zakko
2018-3-9
Hi InterStellar, sorry for the difficulties, I have sent you PM, please check and have a try.
2018-3-9
Ale_Zakko
Ho djiuser_TkHM7! I don't know if I can share my solution because it's a little bit hack the dji assistant ... I'm sorry for that... But you can forward this thread to the online support for the solution.. the solution it's located in the dji assistant that has to open the solution to upgrade the transmitter to the latest firmware 1.1.0.21! They will understand!
2018-3-10
Ale_Zakko
Ok guys!!! Jared from dji told me that i can share the solution!
Here the steps:
1 connect your ronin m transmitter to your pc via usb and fire it up.
2 after Windows ricognized the transmitter, open the latest dji assistant, in this case the 2.5.
3 login with your email and password and go to the update menu.
4 inside the specific upgrade firmware menu tipe with your keyboard "door".
5 a new pop up will appear and you have to type into user and password the word "ronin"
6 this allow to force dji assistant to unlock the latest transmitter version to 1.1.0.21 !!
7 follow the intruction and that's it! Don't be afraid if the update fail first time. This procedure first erase the transmitter firmware. redo the same procedure and dji assistant will install the latest firmware 1.1.0.21 Do the calibration and ronin will works PERFECT!!!
2018-3-10
InterStellar
Philippines
Ale_Zakko Posted at 2018-3-10 00:37
Here the steps:
Nice! Thanks alot! my Ronin RC is now working perfectly with my Ronin-M.
2018-3-11
InterStellar
Philippines
Problem solve!
2018-3-11
InterStellar
Philippines
2018-3-11
Ale_Zakko
InterStellar Posted at 2018-3-11 22:45
https://www.youtube.com/watch?v=zXOwR9UsSZ8
did you calibrate and set to default all?
2018-3-12
The video seems normal now, please provide us more details if there is any other problem.
2018-3-13
InterStellar
Philippines
Ale_Zakko Posted at 2018-3-12 08:10
Yup and now everything works perfectly.
2018-4-4
InterStellar
Singapore
DJI Mindy Posted at 2018-3-13 22:59
I tested my ronin now. After the update my ronin doesn’t recognized the deadband for pan and tilt axis. Please help.
2018-4-7
InterStellar
Singapore
InterStellar Posted at 2018-4-7 03:11
Everytime I connect my thunb control I lose my deadband in my ronin eveb though the settings is set.
2018-4-7
InterStellar
Singapore
Sorry. I solve it.
2018-4-7
I'm terribly sorry for the late response, I just saw your update, but glad to know the issue was figured out, hope you have a great time with it, if there is any other issue, please let us know anytime.
2018-4-11
pedmod1
YEAHHHHHHHHHH FIXED.... THANK YOU  ;> ;) ;o
2018-4-13
PieterWielen
Hey there, I did this update and it work for me!
I only have one problem now.. Mij tilt won't work..
Someone having a solution for this?
It seems like that the ronin M it self, also has a "door" update..
But the password/ username is different
Ronin M it self
Ronin M it self
2020-10-29
