BobWinNV
Flight distance : 284209 ft
1px0ff Posted at 2018-3-8 21:24
I just received my OM2 today, and it is the first gimbal I have ever had. I noticed terrible vibration and horrible noise in the motor when I tried to turn it on one time. I thought I had the phone perfectly balanced but it turns out I was over anticipating how it was supposed to be balanced. After playing around with it, and getting the right balance, it quit making that noise. I have noticed a little bit of vibration on occasion, but it is very slight and usually when everything is moving really fast (though I can't be sure only been using this thing for a couple of hours). I had nothing like the video posted above. That being said, I cannot get the portrait mode to balance correctly and when I do, I can see the OM2 motor in the field of view with an iPhone X
Did you balance your iPhone X in both the roll and pitch directions? Roll adjustments are done by adjusting the length of the arm. Pitch adjustments are done by adjusting the position of the phone in the holder. Start your pitch adjustment by position the phone so that the four metal bars are an equal length.
The iPhone X should not be in any case for best results.
If you use your iPhone X in portrait mode with the back camera then you will need to hold the OM2 in the flashlight mode to keep from seeing the motor. |
