If you are referring to the rattling sound of red propellers like Mr.Mister said, please check if there is foam inside of propellers, if the issue persists with the foam inside, no worries, as the propeller and propeller mounting plate are plastic parts made through injection molding, there might be an engineering tolerance with them. The shipped Inspire 2 aircraft have been tested and quality assessment has been conducted. The tolerances are within a standard range. This issue does not affect the normal use and flight safety. |
