Hello,
The UAV was flying stable until it was disassembled and transported. Now, when hovering it suddenly becomes unstable, and drops in throttle. I have to pull throttle high to make it stable and flying again. Attacing video, please give input or suggestions on what might be causing this issue or if you have a solution to fix it.
Made sure IMU is mounted strong, Gain settings are unchanged as before, all ESCs have same temperature - no overheating, all motors seem to be normal - no overheating, double checked the wiring, compass calibration done successfully.
Hi there, sorry to the difficulties, have you checked if the propeller is damaged? If it is fine and the A2 still in warranty period, we recommend to export the flight log for data analysis.
DJI Mindy Posted at 2018-3-8 22:10
Hello, yes, propeller is not damaged. How to check the date/time on the flight log? There are too many files.
Thank you
UAVProject Posted at 2018-3-8 22:25
Thank you
Please connect A2 to DJI Assistant 2, there should be flight data in DJI Assistant 2 and each data has its flight date, please recall the date when the issue happens and export it.
