Precision Fly Safe Database Update with Cendence / Crystal Sky
1875 16 2018-3-8
Mims
Flight distance : 1686991 ft
I'm getting the update message about the fly safe database. I click Update and see the instruction screen. I dutifully plug in the USB in the Cendense and USB on the Inspire 2. Click OK. Nothing. The update does not start, the instruction window just disappears. I try the microUSB on the Censense. Nothing. I try the USB on the Crystal Sky. Nothing. If I go to About and check for update, it says the database needs to be updated, but I can't get it to start.
What am I doing wrong?
2018-3-8
Rodger8
Flight distance : 15812070 ft
I have the same gear and have not been propted to do an upgrade ?????
2018-3-8
Mr.Mister
Flight distance : 862854 ft
I experienced the same issue. I resolved it by using my iPad to initially update the Fly Safe database, then went back to Cendence and Crystal Sky. You will then get the update message one more time, but when you click update this time, all will be fine.  It actually downloads the Fly Safe database from the aircraft down to the controller.
2018-3-8
Hi Mims, we are so sorry for the trouble caused, like Mr.Mister suggested, could you please update the Fly Safe Database via the normal mobile device? May I have the DJI Go 4 APP in your CrystalSky? We will escalate the issue to our engineers for test and analysis, thank you.
2018-3-9
Rob W
Flight distance : 94390 ft
Sweden
I have this issue, too with Cendence and CrystalSky.
2018-3-9
Rob W Posted at 2018-3-9 01:48
Just to clarify, do you run the latest firmware of Cendence and CrystalSky?
2018-3-9
Rob W
Sweden
DJI Mindy Posted at 2018-3-9 03:27
Yes, I run the latest firmwares. I can connect them I2 and CS, then choose to update the database and then the popup disappears. If I turn off CS and I2, and then boot it up again immediately, the popup comes back and wants me to update again.
2018-3-9
Mims
I also have the latest firmware for everything. Thanks for helping us get to the bottom of this. I'm assuming that I can upgrade simply by connecting the iPad, but I'll hold off in case you want me to try something new...
2018-3-10
Curtis Howard
This is what you do#1 disconnect Crystal Sky from Cendence controller
2018-3-10
Curtis Howard
Disconnect Chrystal Sky from Cendence Controller, plug in a USB cable into Inspire 2 and other end into the small USB connector in the Chrystal Sky monitor. Turn on the Chystal Sky and then the Inspire 2 then the Cendence controller, wait for message asking for update and start update you should see the count down to completion. Thats it !
2018-3-10
rmaxwell.dccnet
Flight distance : 698661 ft
Curtis Howard Posted at 2018-3-10 11:38
Thanks you Curtis for this information.  It worked like a charm.
NOW...DJI and Mindy...Why is this information not in the documentation??  Why could DJI not supply this information????
Please don't ignore this request and tell us why a user has to discover how to update this data base.
Ray
2018-3-13
Hi all, sorry for the late response, the issue has been reported to our engineers for tests, I will come back to you once I get any update, sorry for the inconvenience caused.
2018-3-14
Hi all, thanks for your patience, I have got the feedback from our engineers, when you update the database via Cendence+CrystalSky in M200 series products or Inspire 2, please toggle the USB switch in the aircraft to APP mode, then connect Aircraft to Micro USB port in CryatalSky via an Android cable, power on the Aircraft, Cendence and CrystalSky (CrystalSky is nor needed to be attached to Cendence). Then connect CrystalSky to the network and update the database according to the pop-up window.Hope these steps work, thank you.
2018-3-15
Matthew Dobrski
Flight distance : 1831050 ft
DJI Mindy Posted at 2018-3-15 00:36
Hahaha, Mindy, I just did that and posted How2 instructions on M200 forum!
2018-3-15
Matthew Dobrski Posted at 2018-3-15 00:48
I see, you made it clearer than I did. Well done.
2018-3-16
Mims
That works. Recorded it as a video to help others. The app did crash a couple times when booting up, but got it to work eventually...
2018-3-16
Matthew Dobrski
Mims Posted at 2018-3-16 20:43
That works. Recorded it as a video to help others. The app did crash a couple times when booting up, but got it to work eventually... https://youtu.be/abBy5Kgn2YY
In the name of others thank you for the vid, I was too busy to do it.
BTW - since I see you have Cendence/CS Ultra setup to control your bird ... What average range you're able to fly before transmission starts falling apart?
2018-3-16
