mavic gimble
737 7 2018-3-8
vidya
India
hi, i have dji mavic... The video is not coming and it is showing that gimbal overloaded.... Bcox of what will this problem arise
2018-3-8
chiplifter
Flight distance : 745180 ft
you get a gimbal overload when it is blocked. Did you remove the gimbal cover?
2018-3-9
vidya
India
s i have removed and have done many shoots also
2018-3-9
Robothamster
Flight distance : 51135 ft
I got a gimbal over load when I forgot to unfold the front legs with the wifi antennas before lift of, assume you did that?
2018-3-9
vidya
India
no, i have removed all the legs
2018-3-9
vidya
India
should i replace the gimbal......
2018-3-9
DJI Elektra
vidya Posted at 2018-3-9 04:17
Hi, did you try to flash the firmware with DJI Assistant 2? If the problem remains, please contact our support and start a case: http://www.dji.com/support
2018-3-10
Rottyman
Flight distance : 20561 ft
DJI Elektra Posted at 2018-3-10 02:39
https://www.youtube.com/watch?v=HZE-fP28htI
This will not be warranty work if you send it in.  Be prepared to pay for this fix even if you are in warranty.
2018-4-13
