Replacement Mavic Pro Won’t Connect To App
2710 17 2018-3-9
calmari
Flight distance : 64944 ft
I’ve just received my Mavic Pro back from a repair at DJI Holland. I’ve received a different unit back and now I cannot get it to connect to the app. Is there something I need to do to activate it again or register it with my app or account? I seem to remember being prompted to activate with my first Mavic but not now.
I’ve tried using the standard cable, I’ve tried using the USB port on the bottom of the controller with the other cable disconnected and still no good. i’ve Used 2 different cables for this.
I’ve deleted the app and downloaded again and signed in and tried all the connection options again and still cannot get connected.
What else should I be doing?
iPhone 7+ with latest iOS and DJI Go 4 version. I’ve also tried connecting up an iPad Pro 12.9 2017 using the USB lead and still no good..
2018-3-9
IceBox-Murdock
Flight distance : 43845 ft
Quick question. Are you using the side port to connect the iPhone to your RC or the bottom USB?
2018-3-9
A CW
Flight distance : 13877205 ft
Does it say RC connected before you turn on the drone? Have you linked the RC and AC?
2018-3-9
calmari
IceBox-Murdock Posted at 2018-3-9 16:19
I’ve tried both. Each time I’ve used one cable I’ve made sure the other is completely disconnected.
I normally just use the side port without issue.
2018-3-9
calmari
A CW Posted at 2018-3-9 16:21
On the RC? The RC just says ‘connecting_’, it always has just said that.
2018-3-9
calmari
The linking part is what is missing I think. I thought there was some kind of activation required etc but couldn’t find info. Got some now and giving it a go. Thanks.
2018-3-9
A CW
Link the RC to the drone - loads of DJI tutorials on it. Come back with the outcome!
2018-3-9
calmari
All linked and good to go. Thanks.
2018-3-9
M2Wair
Flight distance : 1192231 ft
calmari Posted at 2018-3-9 16:48
Result....... Bet you were close to pulling your hair out lol
2018-3-9
calmari
M2Wair Posted at 2018-3-9 16:51
My hair is long gone but yes, I was getting very frustrated. I’d checked the Quick Start guide and beginning of the manual and couldn’t find anything. I knew about activation and that was the route I ended up going down but I wasn’t getting prompted to activate.
It would have been helpful if DJI Support were a little more helpful and notified you of this requirement since it is a replacement drone.
Thanks for all the input.
2018-3-9
calmari
Is there a way to find out exactly what drone I now have? Is it a new unit, refurbed or what? It looks pretty new but it didn’t come cellophane wrapped.
The gimbal cover and lock were both off of it when I opened it all up.
2018-3-9
DJI Elektra
calmari Posted at 2018-3-9 17:06
Please try to connect your RC with DJI Assistant 2 and see if it can be recognized. Or you can try to use an Android device. Thanks for your support.
2018-3-9
A CW
Fantastic! Good to see that sorted it!
2018-3-9
A CW
Mavic Pro's are not not wrapped - just the Spark and Mavic Air.
2018-3-9
calmari
DJI Elektra Posted at 2018-3-9 20:26
Thanks. My initial connection problems are now sorted. Will connecting to DJI Assistant be able to tell me if it is either a new or refurbished unit?
2018-3-10
calmari
A CW Posted at 2018-3-9 23:32
Okay, thanks.
2018-3-10
A CW
calmari Posted at 2018-3-10 00:03
No - just what firmware it is on - best to update to the latest version on both the AC and RC using Assistant 2 then any additional batteries via the app.
To tell the age you will need the serial number - google how 'old is my Mavic' - there are plenty of sources outside of this forum that will tell you when your replacement unit was manufactured.
2018-3-10
Like A CW mentioned, the DJI Assistance 2 is used for update firmware, export log, calibrate vision system and so on, please note that products and components presented for repair may be replaced by refurbished goods of the same type rather than being repaired. Please test the flight performance and keep us updated if there is any further problem with the drone.
2018-3-11
