AIR - Smart batteries or not?
788 8 2018-3-9
Crazyant
Flight distance : 852392 ft
Switzerland
Hi all. I noticed that my batteries are not discharging automatically even after several days... i could not find anywhere in the dji go app the option to select dischard window period.
Arent these smart batteries?
2018-3-9
Wachtberger
Flight distance : 261509 ft
They do it automatically after being idle for 10 days and you cannot change the setting.
2018-3-10
FlyDK
Flight distance : 1636286 ft
Denmark
If Air's batteries otherwise work like them for Pro, then the countdown for auto-discharge resets each time the battery button is pressed. In other words; do not check the voltage on the batteries before a few weeks have elapsed.
2018-3-10
DJI Thor
Flight distance : 13602 ft
Yes, it's the intelligent battery. Like the answers above, the battery will auto-discharge after 10 days. And if you check the battery during this time, the time will be reset.
2018-3-10
Crazyant
Switzerland
DJI Thor Posted at 2018-3-10 01:55
Thx. Also what about the question whether they are LiPo or LiCoO2?
2018-3-10
Wyke
Flight distance : 33166 ft
Crazyant Posted at 2018-3-10 02:47
They are LiPo as in Lithium Polymer, using LiCoO2 or Lithium Cobolt Oxide in their electrodes
2018-3-10
$gambino$
Flight distance : 1563980 ft
They are lipo and why in the world would u leave your batteries charged for several days so they can discharge themselves???   U should never leave them fully charged for more then a day.   U should go have a read about lipo's or their cycle life will be very short. Abd will not perform correctly! Never discharge them past 20% and if u do leave them somewhat charged it should be at storage charge. 30% is sufficient
2018-3-10
Crazyant
Switzerland
$gambino$ Posted at 2018-3-10 20:08
Dude you didnt get the question. In P4 series you could choose after how many days, discharging would kick-in. I usually had 3 days. My question was, that I could not find this option for the Mavic Air and I have noticed that after several days, the batteries did not get discharged. So now I understood that you cannot change this parameter for the air and that it takes 10 days for the discharge to take place.
2018-3-11
DJT_MVSP
Flight distance : 2018645 ft
Singapore
Unfortunately, these newer DJI drones like the Spark and the Mavic Air have hard coded the auto discharge at 10 days.
2018-3-11
