Side RC Connection Problem
381 5 2018-3-10
fans052b845c
Flight distance : 175646 ft
Hi,
I am only able to wired connect wioth bottom USB port top the phone which is painful and unsightly. I am unable to use the side RC connection as it wont go past step 3 and connect.
I have tried 2 Android phones and both have same issue. Any ideas? Latest firmwares etc
Thanks
Chris
2018-3-10
M2Wair
Flight distance : 1192231 ft
More importantly are you able to charge your RC via the side connect!
2018-3-10
fans052b845c
Yes i did that with the lead and little adaptor yesterday
2018-3-10
M2Wair
I would be inclined to buy a new cable  (this works on the Air too)
https://www.amazon.co.uk/Kismapl ... i+spark+accessories
2018-3-10
Mari
Flight distance : 1308780 ft
... there are many posts on this forum about not able to connect device with RC using the side-port of the RC... I most cases the result of a bad cable. You can replace cable, but since there are a lot of problems with these cables....
2018-3-10
DJI Susan
Hey Chris, it looks like the cable issue. Please change to another working cable to see whether it helps.
2018-3-11
