KurtVD
Flight distance : 365299 ft
Switzerland
It should work even when the battery is low, and you can use the RC (controller) while it is charging. It can take a minute or two until the RC connects to the aircraft, but if it doesn't, there's a procedure to link the aircraft to the RC. But you might need to reset the existing connection, I think the procedure from the manual to un-link the RC should do it, but I'm not sure (since I never had to do it myself). See for yourself (Copy/paste from the manual):
Linking the Remote Controller
The aircraft and the remote controller are linked before shipment if you purchase the Spark Combo (with the remote controller included). To link a remote controller to Spark, follow the instructions below:
1. Power on the aircraft and the remote controller. Wait until the aircraft status indicators blink yellow.
2. Press and hold the power button of the Intelligent Flight Battery for three second. Release the button
after hearing a single beep. The front LEDs will blink red.
3. Press and hold the Flight Pause button, the Function button, and the Customizable button
simultaneously. Linking begins when the alarm becomes a quick single beep after an alternating single/double beep.4. Then the front LEDs turn solid red after blinking green. When the status LED on the remote controller
turns solid green, linking is complete.
Ensure the remote controller is within 0.66 ft (20 cm) of the aircraft during linking.
Disconnect the Remote Controller
Apart from using the remote controller, you can control the aircraft using virtual joysticks in DJI GO 4. However, when the remote controller is linked to the aircraft, virtual joystick control is disabled. You need to disconnect the remote controller and aircraft to enable virtual joysticks.
1. Power on the aircraft.
2. Press and hold the power button of the Intelligent Flight Battery for six seconds until hearing a double beep, which will disconnect the remote controller and aircraft.
