JKolar
We use Pix4D Capture with our M200 daily, you will just need to ensure you have the latest version. If you are lucky enough to phone service in the field you can load the background image with it, alternatively you can download the image in the office where you have internet connection and store it on your device. We simply use a Samsung Tab A tablet (android), not the CrystalSky. If your area is quite large, you can do 2 things to maximize your flight area; Raise the flight height up (we usually fly at 80m) or you can reduce the image overlap. I would recommend that if you are flying in undulated/hilly terrain that you try and fly from the highest point otherwise you may get areas of your flight not stitch due to an overlap issue. We also use Pix4D Mapper to process our flights to generate orthomasaic geoTIFF images and point clouds.
Note: the latest version of Pix4D Capture supports the M200 & M210 series in the list of available drones, previous versions used the flight controller of the Inspire 2 series. Also you will need to use the CTRL+DJI app in combination with pix4D Capture (don't know if this applies to the CrystalSky). |
