Skymax.
I'm no expert but here are some plausible causes I read here.
First flight new MP with iPhone 6S+, in LOS and distance only a hundred feet or so, Alt 200Ft.
One word "Disconnected" HUD remained, video link fail black screen.
RTH initiated, MP returned safely, "Have you tried turning it off and on again?" lol
Took off same thing happened, RTH worked, noticed phone was hot on the back, checked temp 54C.
Possible causes after hours of Forum reading.
1. The lightning cable on the side is virtually a Ribbon with no shielding and I was taking off only 150Ft from some 25Kw power lines strong EMR can cause this.
2. I did not have Aeroplane Mode selected.
3. It was a hot day and even a powerful phone is working hard Receiving and Saving all those video frames as well as everything else it has to do.
Remedies:
1. WiFi off.
2. Aeroplane Mode On.
3. Got a quality USB to tablet cable, a real Apple One that does not have Cheese insulation and plug it in to the bottom Controller Port.
4. Bought a Mint iPad AIR2 for $300 from a Refurbisher it runs at 31C when the air temp is 31C. (And has a brighter screen than a Mini.)
Have not had a single "Disconnected" since these changes. I believe these steps can eliminate most Disconnections and if they don't they will take you closer to the problem source by eliminating the most common.
(There are several types of DISCONNECT and each can have more than one cause though not necessarily simultaneously so it's a puzzle that sometimes has to be solved only One step at a time.)
Good Luck, stay in LOS until you find the bug.
