I finally installed the FatShark Pan-Tilt gimbal on my MiniDrak and got everything working.
I'm missing an option for servo-reverse in the google's gimbal setup. I had to resolder one servo to geht the left/right direction working (you need to open the servo and exchange + and - to the motor and swap the two outer cables to the poti.
The "servo offset" does nothing at all in my case
Increasing the gimbal sense works, but if you move/rotate your head above a certain degree the servo will suddenly swing to the oposite direction instead of stoping at the end.
So there is still some space for improvement - hope DJI will continue with improving the Air unit
Another tip: whenever you turn the Headtracking on current direction of the googles will be reassigned to the center (forward) direction of the gimbal/servo.
So if you take off your aircraft looking in one direction but want to e.g. sit down in a different direction simply turn off/on Headtracking to reset it
Kryml Munsta Posted at 2018-3-26 05:02
Hi, after long time testing, when did you do a good product, my main complain are :
- no technical support
- no option for reverse servo in gimbal menu
- no option to record OSD, at least GPS coordinate
- no access to log file
