maurom82
Flight distance : 143757 ft
W.T. Foxtrot Posted at 2018-3-11 18:05
I only managed to force mine into holding a manual setting once -- and it was by going into a different quickshot mode first. (It's how I managed to get the blue sky in my avatar on a VERY bright day and no ND filters) However, the norm is that the Asteroid mode will set everything to AUTO, and all manual corrections are switched off. The only reliable answer is ND filters -- which you will find can really improve your footage in all modes. Also, the camera seems to set the overall exposure bracket from the initial direction you are facing for these. Try rotating around your subject 90 or 180 degrees from the starting point and see if you can improve the results using this different heading.
I will try it, thanks a lot. I hope that DJI will change the first photo shoot (that is the one that set the exposure) to the straight position instead of the lowest position, in this case the exposure would be better, as shooted with litchi (I read this, I do not use Litchi) |
