snk
Flight distance : 7323 ft
Hi everyone,
I would like to film an object 360 degrees using a drone. I would like the drone to start filming as soon its airborne then start to rotate around an object going up at a certain rate while revolving around the object. so, in the end, the video should look like a capture of the object from bottom to top in 360 degrees spiral. can this be done using a Mavic? can it be programmed that way?
thank you
regards
SNK
