embayweather
Flight distance : 556667 ft
Whilst taking the test flight also use the opportunity to look at the state of the battery and other information available in the menus. Check along the lines of fir of the two halves of the hull to see that they are joined up correctly, and of course, check for any cracks, small or otherwise in the hull and legs. If all is well then it is a superb aircraft, you will not be disappointed. |
