RichJ53
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
Flight distance : 1837356 ft
Genettico
Yes, I show some photos of the power supply energized in Bob's blog. I was using it at 15.2V 5.5 amps for charging a three cell battery from one of my other copters. yeah, I sent it back after trying it, it was clearly defective, fans were noisy accuracy on the meter was poor and only allowed voltage to 29V (not 30v). eBay for 249 bucks
read the blog: When you assemble everything, power supply, three battery strip connector board, they should all work fine, but the connector strip may require support (thin PC board). the batteries will charge correctly and faster over all because they will each charge at 200 watts based on the intelligent battery logic circuit.
Respectfully, you do not need to regulate the amperage, only set the correct voltage and the intelligent battery charger will do the rest. It will only pull the required amps at 200 watts... that's it. The power supply will not provide any more or less than what is being asked of it.
Rich |
