DJI Susan
Thanks for getting back to us. It seems that I do not make this clear, sorry about this. I'll list these points one by one for better understanding. Please correct me if there is any misunderstanding.
1. The issue only appears in 4K 30fps and 4K 60fps, right? Or all 4K videos have the same issue?
2. Does the issue appear in every MOV videos? Or only some MOV videos?
3. The original SD card has been fully tested, I'll recommend having a try if applicable. Please check whether the local dealers can help.
4. If the issue appears frequently, you can refer my previous suggestions for troubleshooting first.
1) Connect the drone with PC, or take out the SD card and read it via card reader, do not open the file in the SD card directly;
2) Copy the whole file of SD card to PC directly, do not delete the original ones on the SD card.
3) View the copy file on the PC to see whether the issue appears
4) If yes, please insert the SD card to aircraft directly, connect the APP to view during playback to see whether you get the similar issue. Also, you can try to change the SD card reader or PC to verify.
