user284e4968c4
Flight distance : 371555 ft
Hi Everybody,
Recently returned from a long shooting job in Central CA with the Inspire 2 with all latest firmware and Cendence. I put a considerable number of hours on both the aircraft and batteries, often in colder temperatures, near the sea, with atmospheric moisture present. Was shooting a car job, so chasing automobiles in sport mode a lot of the time, pushing the bird nice and hard. All things considered, I was super impressed with how the bird held up. However, I did notice some salt build-up on the props from being in heavy mist near the sea. Definitely had to wipe some moisture droplets off the lens as well. Bird flew perfectly on my last flight where I drained the batteries.
After returning hope and visually inspecting the bird, I found two physical issues that concern me:
1. Moisture or lubricant (?) secretions from the seam/crack on both sides of the component with the "Mind Your Fingers" sticker on it. Photograph below. By itself probably not a big issue but worth nothing.
2. Two pieces of plastic molding adjacent to the battery terminals have become slightly looser than originally manufactured, creating some gaps in the flat plastic area that faces the struts. I can tell they are looser than they should be because if I push them back in from both sides, they become much more flush. This has occurred somewhat symmetrically on both sides. Very difficult to photograph this, so please bear with me.
Can anyone think of whether or not this is a cause for concern? Bird is about 1.5 years old, and has seen a fair bit of action: 122 flights, 22 hours of operation on the aircraft, flown about 1,017,026 feet, or about 192 miles.
If somebody tells that the wind blew it apart over time and that the bird is fine, I'll take that. But I worry about moisture expanding some of the components or wreaking havoc inside the bird. Last I checked, flies perfectly. My backup is Inspire 1 RAW and I am very loathe to let the Inspire 2 out of my hands for any amount of time, as I use it to make money.
Any thoughts?
