hallmark007
Flight distance : 9827923 ft
n8blogg Posted at 2018-3-15 09:51
hallmark007, thanks for the feedback. I definitely understand what you're seeing on the flight log, but I wasn't holding down on the joystick to make it descend. In the log you can see a few times, when the drone was at 0 mph I was letting off of ALL controls to see if it was still dropping, and it was. It was essentially responding as if the joystick was stuck in the down position to make the drone descend, although the stick wasn't stuck or anything.
I'm certainly no drone expert or anything, but I promise you I'm not stupid enough to hold down the joystick and then ask why my drone was descending. I was actually pushing the joystick up for part of the time to see if it would respond and and climb in altitude as I moved it back towards us a little bit. My cousin (who has flown a mavic pro for a few years) was watching this as well and was equally as concerned/confused that I wasnt controlling the descent.
I’m not casting aspersions on anyone, I take you at your word, then the problem is that log shows aircraft descending it also recorded right stick throttle in the downward position, only thing I can think of is you might need to do a RC stick calibration, once you go into calibration you should be able to see if there are any anomalies, also it is possible that RC sticks can be affected by magnetic interference, but I’m not so sure in this case. |
