Fly Away Bubble
2973 6 2018-3-12
fans0d68bf90
Flight distance : 2920 ft
Anyone know how to calculate this to help locate after a flyaway occurs?
I need to know for my assessment this weekend, i've looked for hours on the net to no avail.
Any help on this is greatly appreciated!
Thanks.
2018-3-12
DJI Susan
Hi there, have you tried to search via the feature of Find My Drone? Please click the three bars in the right upper corner to check.
2018-3-12
fans0d68bf90
DJI Susan Posted at 2018-3-12 19:49
No i havn't, i'll try that thanks.
I do need to know the 'manual' solution to recovering the drone also.
2018-3-12
DJI Susan
fans0d68bf90 Posted at 2018-3-12 23:47
If you fly with DJI GO/DJI GO 4, the flight records will be saved in the mobile devices. You can check the last coordinates on the flight records to locate the drone.
2018-3-15
fansfd3dece0
Flight distance : 195850 ft
Hey there, did you ever get the answer? I have also been looking for hours and need to put it in my ops manual. Thanks
2019-7-7
fans3ff40fd7
Hi, The flight bubble is the area that the drone could potentially land / fly to when a flyaway occurs.  This is calculated by the max speed of the drone x the time of life left in the battery.  So if your drone can do 20mph and you have 15 minutes flight time left =, the bubble is a circle with 5 miles radius from the point the drone was last seen.  You need to alert any potential airspace users within this bubble.  Hope this helps!
2019-9-3
fans3ff40fd7
2019-9-3
