DJI Thor
Flight distance : 13602 ft
Leonardobhz Posted at 2018-10-1 08:14
Hello, including the Lexar - Professional 128gb brand to use on my dji phantom 4 pro drone, but when I called the drone, RC and DJIgo4, it showed me an Unknown SD Card Error message. Can someone help me?
Hi Leonardo, just to verify, is there another SD card to try? Please try to change the SD card and see if the error exists. If the issue is not existing on a different SD card, you can try to format the Lexar - Professional 128GB on the PC first and format again on the drone, please check if this works, please note to back up the needed files first before formatting. Besides, please keep all firmware updated.
If the error appears on different SD cards, you may need to send the drone in for diagnosis, please contact our support for a further help http://www.dji.com/support. Thank you. |
