DJI RONIN MX WITH SONY FS7
7359 4 2018-3-13
MARATMUR
Russia
HELLO! Who used the RONIN MX TOGETHER WITH SONS FS7? PROMPT, HAS YOU GOT?
2018-3-13
DJI Sammy
Flight distance : 225564 ft
New Zealand
To big!! you will need a Ronin 2
2018-3-13
The Ronin-MX supports a wide variety of camera systems that weigh less than 4.5kg (10lbs). This includes ARRI ALEXA Mini, Canon 5D MK III, Panasonic GH3, Black Magic Cinema Camera, Canon 6D, Panasonic GH4, Black Magic Pocket Cinema Camera, Canon 7D, RED EPIC, Canon 1Dc, Canon C100, Sony Alpha 7 Series, Canon 5D MK II, Nikon D800.
Here is the Camera Tray Dimensions:
Maximum depth from the center of gravity on camera base plate: 120mm
Maximum height measured from the top of camera base plate: 130mm
Maximum width: 160mm
2018-3-13
visionrouge.net
DJI Mindy Posted at 2018-3-13 22:40
There are always a way to make things work, I did with the Ronin M and use it almost every week with success.
http://www.visionrouge.net/web/2017/04/sony-fs7-on-dji-ronin-m/
Depend on the lens , follow focus, and extra gear you are planning to use.
I will not consider that it's great to send this in the air, but if you are on hand gimbal system, I guess you just have to use the right lens and strip your FS7 as described..
2018-4-14
brennen hendrix
DJI Mindy Posted at 3-13 22:40
Will the Mx hold a canon 7d mark ii
2018-12-30
