hallmark007
Flight distance : 9827923 ft
There is much confusion with calibration with dji, Mavic when first introduced instructions were to only calibrate when prompted by app ,now there is a change in the manual tells you to calibrate every (10km) of movement, in spark phantom and inspire don’t calibrate unless prompted by app, so dji is not really sure why or when you need to calibrate, as it says in the MavAir manual it is recommended if you move 50km , I for one don’t really buy this I’m just back from a 2000 mile trip to Sweden where I was not prompted to calibrate so I didn’t but checked compass levels just to make sure and everything was fine.
I’m thinking dji are trying to figure out what is the best practice for users to avoid getting a bad compass and I believe they still haven’t found the answer yet. One good thing they have included in MavAir is it won’t let you take off if it thinks there is any problem with compass, but I have checked the green bars when getting this warning and it reads perfect, so this is a bit of a conflict and this is why I think dji are still unsure what to do themselves.
This is just my opinion on compass in all of Aircraft I mentioned above for what it’s worth.
Calibration gives the compass the information it needs to determine which magnetic influences are part of the MavAir and what is the earth's normal magnetic field.
The compass doesn't lose calibration and doesn't ever need re-calibration unless you add or remove equipment to/from the MavAir.
