X1 no sign of life
1335 5 2015-5-5
quentin.pardo
Hi comunity ! i got a problem with my phantom 1 , i bought a feiyu g3 utlra and adapt it on my phantom .
But my Pitch control knob on my rc controller (v4) has no sign of life , even in the naza assistant , every other knobs works but the X1 don't .
Do you have a solution with that ! Thank's
2015-5-5
nig_smith
Have you connected the pitch control from the gimbal to the F2 port on the Naza Flight controller?
You will also need to calibrate the X1 channel in the Flight Assistant software.
Regards
Nidge
2015-5-5
ShadyDealer
Flight distance : 983428 ft
I had the same issue. Several attempts to calibrate the controller between the Naza assistant and RC Assist. Eventually, more luck than anything else I got it to work.
2015-8-12
DJI-Dave
that should do it
2015-8-19
ShadyDealer
Took me several attempts between Naza Assistant and RC Assistant software
2015-9-15
RATTYDUDE77
Flight distance : 2917 ft
Did you get it to work
2016-4-10
