btonetbone
Flight distance : 18350 ft
Certainly, here's the link to the entire folder: https://drive.google.com/file/d/1n_MeCmuL_4-jMvyaTlO64v0xzOnCiw_8/view?usp=drivesdk
The date of the incident was February 18, 2018.
My Mavic Air crashed and I believe that it may be a problem with the drone or perhaps programming error in the SmartCapture feature.
I was trying to show my wife how some of the features work, and we launched (precision launch) from the third floor balcony on the rear of our condo. I took it up to an additional 12 feet higher and zipped around a little bit, which is high enough to avoid the few obstacles back there.
I brought it back in front of us, still about 12 feet up. Then, I turned on the SmartCapture gesture control and the Mavic Air dropped height almost instantly by 6ish feet. Within moments, it had lowered enough where it got stuck in a tree. It then flipped over and fell about 50 feet to the ground.
In hindsight, I'm aware that I could have likely either pressed Pause or exited the SmartCapture mode, but it happened so quickly that I was shocked and didn't respond fast enough. I didn't see anywhere in the manual that SmartCapture will automatically lower to a certain height, and was quite surprised.
I replaced the propellers, but did not see any physical damage of note on the drone. I recalibrated the IMU, gimbal, and Compass. However, the drone felt a little jittery afterwards. I don't know what was going on with it, but it never felt quite stable again after it fell. |
