Compatability of Z3 Camera With S1000+ and LB2 with A3 Pro
1587 4 2018-3-13
fansa7e34cd9
Flight distance : 2538474 ft
Can anyone confirm that the Z3 camera can be used with the S1000+, LB2, and A3 Pro FC if using the M600 adaptor kit to mount the camera ??
2018-3-13
Yes, you can, they are compatible in software, but you might need to modify the aircraft.
2018-3-14
fansa7e34cd9
DJI Mindy Posted at 2018-3-14 00:05
thanks mindy, presume you just mean the gimbal mounting bracket from the M600 ??
thanks for your help
2018-3-14
fansa7e34cd9 Posted at 2018-3-14 10:30
No, I mean the aircraft body, the hole will be needed to mount the gimbal, but sorry that we are unable to provide any support for modification.
2018-3-16
fansa7e34cd9
DJI Mindy Posted at 2018-3-16 01:41
surely the mounting is the same fitting as would fit the X3 from the inspire ???....the M600 mounting plate already has the fitting integrated into the plate which is then just mounted under the existing rails of the S1000 ???
2018-3-16
