Geebax
djiuser_723Dvno4bPgl Posted at 2018-3-13 16:40
I have a pretty fast pc, very fast when I built it but may have to be upgraded. However, the video is choppy in live view at the time I take it as displayed on ipad mini 4. Then files are downloaded to pc, and they play back the same as when originally recorded.
Where are you downloading them from? If they still look choppy, then you are probably getting the files from the cache in the iPad Mini 4. Try popping the SD card out of the aircraft, it has the real files. Place the SD card in an adapter and copy them to your PC. BTW, the files may look glitchy when viewed on the iPad Mini 4, but that is relatively normal, they are a downscaled copy to be used for framing and preview purposes only, and can be subject to transmission problems.
