Charge 2 battery at sametime?
1126 11 2018-3-13
Ken Huang
Why my Mavic pro charger charge 2 battery at the sametime now? it use to charge 1 at a time.
2018-3-13
A CW
Flight distance : 13838848 ft
Is this the standard or advanced hub?
2018-3-13
Ken Huang
A CW Posted at 2018-3-13 23:31
It is a standar hub.
2018-3-13
A CW
That is strange - is it a one off or do they constantly charge simultaneously each time you put them on the hub.
2018-3-13
Ken Huang
A CW Posted at 2018-3-13 23:45
It happen for last 3 times, I think it's a good thing, save a lot of time, but I don't know is that something wrong with charger or not, maybe I should check battery, they only 1 year old.
2018-3-13
A CW
Ken Huang Posted at 2018-3-13 23:53
It is a good thing providing it is not doing any harm to the charger, hub and more importantly the battery cells. It looks like there is fault somewhere. As nice as it is to get simultaneous charging from the standard hub it is not designed to do that so it could end up causing serious problems later down the line.
The only thing I can think of other than there being a fault is the mAh capacity in each battery has depleted so much over such a long time that the hub see's your two batteries as having the same capacity as one. Interesting to see though.
2018-3-14
DJI Thor
Flight distance : 13602 ft
Could you please provide me with a picture of your charger hub including the specs, I will like to have our engineers to check.
2018-3-14
Ken Huang
DJI Thor Posted at 2018-3-14 04:58
Thank you very much.
2018-3-14
W.Cordes
Flight distance : 138793 ft
Mine is doing the same thing, has been doing since new.
2018-3-14
fansf77370fb
Flight distance : 1008924 ft
That’s the way should be from the get go
2018-3-14
Montfrooij
Flight distance : 2560453 ft
Mine did sequential charging. So not parallel.
2018-3-14
DJI Thor
Thank you for the info, had forwarded to the engineers to confirm.
2018-3-16
